heater not very hot.
I have a 94 gsr with a y7 sohc in it. i just replaced that thrrmostat on it and the heater still doesnt blow out very hot air. Any reason why?? any help on what to start with??
Thanks for any help
Thanks for any help
Is your heat gauge rising to a normal level?
You could have air in the system, or you could have a leak somewhere...check your system and try bleeding again. If the reservoir emptied, refill it. If it keeps doing that, you've probably got a leak. I had the same issue, and my radiator had 3 leaks and I was only about 3/4 full of coolant.
Wrona
Nov 6, 2011 02:26 PM
fast+forward
Jan 29, 2007 03:13 PM
