TDC Problem?
Old Nov 17, 2008 | 06:44 AM
Brandoff's Avatar
Default TDC Problem?
I purchased a brand new distributor from Advance 2 months ago. About a month ago my car wouldnt start and it was throwing a TDC code. Well i took the distributor back and replaced it with a warranty replacement. Worked fine for about a month and now its doing the same thing. Has anyone else had this problem? Could there be something that is causing this to fail or is it just cheap garbage?
- Brandon
Old Nov 18, 2008 | 06:44 AM
Brandoff's Avatar
anyone?
Old Nov 18, 2008 | 07:19 PM
JNocon's Avatar
I think it's time to look into your service manual, check the trouble code(s), and the solution to your problem(s) should be printed next to it.
Old Nov 19, 2008 | 04:29 AM
mmuller's Avatar
Mad Scientist
try swapping ecus.
and no, nothing is related; either ecu, wiring to sensor or sensor
AnonymousTeg
Mar 15, 2011 08:35 PM
civicsi_5289
Aug 25, 2008 09:36 PM
Geezer
Jun 22, 2005 03:41 AM
Rod.
Jan 2, 2005 11:33 AM
djtony5
Feb 20, 2003 10:09 PM
