QICK CEL Q
i have a 00 EX civic and i did the cel code reader thing, and the code came back 9 long flashes. and there is no cel #90 on the list. what could be going on. what is the time lapes between cel codes if you have 2?
Are you sure that it's not code 9 or 91???
Codes are usually like: Flaaaasssshhh, flash flash flash flash, for say code 14
or if you have 2 codes: Flaaaasssshhh, flash flash flash flash..............flaaaasssshhh flaaaasssshhh, flash flash, indicating codes 14 and 22.
It's hard to describe the timing over a forum but if you read the scentences at normal speed that should get you close.
