Suspension & Brakes Theory, alignment, spring rates....
98 Civic Ex with drum brakes swapping to rear disc & keeping ABS **Questions**
Old Nov 16, 2008 | 04:07 PM
mrbigg9032's Avatar
Default 98 Civic Ex with drum brakes swapping to rear disc & keeping ABS **Questions**
Ok I have a 98 honda civic ex with ABS & rear drums. I want to swap to rear disc & keep ABS. I already bought a rear disc swap from a 99 Acura GSR with ABS sensors.
1) Now my questions are can I use a 99-00 Si porportioning valve (non ABS) with this swap or does it have to be a valve from a gsr?
2) Will the stock ABS computer work even though it is now rear disc?
3) Are the drum brake ABS sensors the same as the disc ABS sensors?
Please dont give me answers like just take out ABS because thats not what I want to do.
Old Nov 16, 2008 | 08:14 PM
reaction360's Avatar
Default Re: 98 Civic Ex with drum brakes swapping to rear disc & keeping ABS **Questions** (mrbigg9032)
1. You do not need to change your proportioning valve as 96+ civics all came with the same valve as the SI model with 4wheel disc.
2. The computer shouldn't have an issue as it just needs to read the tone ring on the hub. which the gsr will have.
3. I don't know if the sensors are different or not, but they maybe bolt up differently due to the difference in the drum/disc spindles.
Old Nov 17, 2008 | 03:39 AM
mrbigg9032's Avatar
Tanks for the info anyone else, maybe someone with first hand experience
Old Nov 18, 2008 | 03:10 AM
mrbigg9032's Avatar
I'm still confused about which porp valve I can use. SHould I usa a abs gsr or a 99-00 si (which I have already.
Old Nov 18, 2008 | 04:15 PM
hatchling37's Avatar
The prop valve on your car is identical to the one that came in the 99-00 Si. If it's in there already, and you have ABS, I would just leave it.
Old Nov 19, 2008 | 03:07 AM
mrbigg9032's Avatar
Their not identical the part #'s from honda are not them same.
Anyone else with info that can help..
Old Nov 19, 2008 | 03:44 AM
mrbigg9032's Avatar
Any brake experts?? (hint hint)
Old Nov 19, 2008 | 06:50 AM
Why don't you just PM him?
Old Nov 19, 2008 | 08:42 AM
SoCal EJ1's Avatar
non abs and abs prop valves are different.
Old Nov 19, 2008 | 04:17 PM
mrbigg9032's Avatar
I was figuring they were diffrent.
There is just a lot of "what ifs" about this swap that i don't have answers too.
Old Nov 21, 2008 | 04:19 PM
mrbigg9032's Avatar
Anyone else?
Old Nov 25, 2008 | 03:18 AM
mrbigg9032's Avatar
Stil confused which valve to use!! Anyone else!
Old Nov 25, 2008 | 08:03 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
prop valves for rear disks and rear drums are different.. drum brakes always have pressure applied, and disks aren't the same (or vice verca)
Old Nov 25, 2008 | 08:04 AM
the prop valves shouldn't (a/e)ffect the ABS.. there are rings on your axles that tell the abs computer if your wheels are locked up..
Old Nov 26, 2008 | 03:13 AM
mrbigg9032's Avatar
Good point, I think my best bet is to use a 99-00 si porp valve.
Old Nov 29, 2008 | 09:26 PM
i edited the 2nd to last post i did.. but yeah prop valves for drums, and disks are totally different
Old Nov 30, 2008 | 05:38 AM
mrbigg9032's Avatar
Ya thats why I think using a 99-00 valve will be my best bet.
Old Dec 1, 2008 | 11:42 PM
burningrex's Avatar
use the 99-00si prop valve!
Old Dec 8, 2008 | 11:47 AM
Katman's Avatar
I'm personally not sure if the Si and Non-Si prop valves are both 40/40, but regardless of that, the Si and Non-Si prop valve part numbers are going to be different because they're from different model civics.
Old Dec 8, 2008 | 12:42 PM
kommon_sense's Avatar
He has an ex which is the *ONE* 96-00 civic which had a different prop valve. The dx/lx/si/etc. all used the same valve, but the ex was the exception.
Old Dec 8, 2008 | 01:37 PM
Katman's Avatar
oo noted! thanks Kommon
by being the exception, it's not a 40/40 prop valve but something less?
Old Dec 8, 2008 | 08:01 PM
I'm not sure what the proportion is. I just recall it having a different part number. I went through all of this when I did the rear disc conversion on my 98ex.
The ex kind of had the oddball brake setup out of the bunch with the big front discs and standard rear drums.
mrbigg9032
25
Jan 14, 2013 09:49 AM
geebs
Mar 2, 2009 03:02 PM
ceezo70
Dec 10, 2008 12:36 PM
c1_sleeper
Suspension & Brakes
Oct 16, 2008 07:10 PM
