fs: 97 gsr 4dr DB8 cypress green pearl
Vehicle will come md state inspected and all parts not installed will be installed before delivery of vehicle.
97 DB8 Cypress Green pearl
147,196 miles
$3500 Firm.
Call 301 802 3824 Kevin
Recently replaced tires, brakes, tune-up, timing belt and associated seals, water pump, and all fluids. Transmission was recently replaced b/c of a grind in 2nd - 3rd any rpm above 5k. A/c compressor replaced summer of last year, is currently discharged b/c of a clogged orifice tube, and receiver dryer that needs replacement. Which I have but haven't had time to replace. The head unit doesn't work b/c when i disconnected the battery to do the timing belt and other things I don't have the code. Have replacement Head unit. I believe its the passenger front speaker that is blown can't remember. Have aftermarket door speakers to replace them.
98+ front end conversion
98 ITR air box
hid's 5k
Parts not installed.
Tokico illuminas (adjustable one) with eibach springs (1.5in drop) - removed it when i did the brakes so I could repaint them. The paint was starting to chip.
Powerslot rotors. I replaced them with factory rotors b/c they are slotted, and the sound they made scared her. Wasn't loud but it make a groan. I guess driving w/o a radio plays with your mind if you don't trust the car. Also needs and exhaust the wrapping around the exhaust is peeling away. Again which I have but have yet to install.
Well that is as honest as I can be. I had a child about 6 months ago, purchased a new home, and just really haven't had time do do anything on the car. If you have any picture request let me know. Time is in short order and I will do my best to get them asap.
147,196 miles
$3500 Firm.
98 ITR air box
hid's 5k
