volt regulator help
Old Nov 15, 2008 | 09:59 PM
BIG_WILL's Avatar
Default volt regulator help
so i bought a new alternator and the battery is still not charging. is there any fuse or somting that could be bad that i can change to get the voltage regulator to turn on?
i believe that is all i have left to do ive done the list trust me.
thanks
Old Nov 15, 2008 | 10:17 PM
Ruben19's Avatar
check the alternator harness and plug for corrosion or tears.
I think hondas have a alternator fuse under the hood fuse box. not 100% sure.
Old Nov 15, 2008 | 10:21 PM
BIG_WILL's Avatar
Default Re: (Ruben19)
its not that cuz i check the power its producing and it is the same as the battery like 11 somting and i know its supposed to be like 13-14. so i am thinking the voltage reg isnt turning on.
Old Nov 16, 2008 | 05:04 PM
Ruben19's Avatar
voltage regulator is inside the battery.
When the engine is running the voltage should be aroud 13.5 to 14 ish.
when engine off the lowest voltage is around 11ish
alperx
Nov 27, 2012 05:47 AM
Yoitshector
45
Aug 25, 2012 08:27 AM
Annihilator
Oct 14, 2009 04:55 PM
lmike6453
Jan 16, 2009 06:55 PM
