At the last part. Balancer belt and TDC
Old Nov 15, 2008 | 07:09 PM
jay24k's Avatar
Default At the last part. Balancer belt and TDC
In the helms manual, it is kind of confusing.
When putting on the balancer belt, does the timing belt need to be at TDC?
Also, I was curious, why does the balancer shaft have to be lined up with the maintenance bolt? Does the front and rear have to work in harmony thus lining them up? I'm just trying to understand why so I can visualize the inner parts better.
Last question, if I tighten the crank bolt as best I can, you think it would be fine till I drive 15 miles to the dealership? They are really cool with me and are going to torque all my high torque parts to spec for free.
Thanks guys.
Old Nov 15, 2008 | 07:17 PM
m00nr0ck Si's Avatar
Default Re: At the last part. Balancer belt and TDC (jay24k)
yes you need the timing belt at tdc while putting a bolt in the maintenance hole to line up the balancer belt......
and I would deff. use a cheater bar to tighten the crank pulley down even if i was just cranking the engine ......
carnot's Avatar
yes, cylinder #1 needs to be at TDC when installing the balancer belt. The front balancer shaft has a mark on it and needs to be lined up with the mark on the block. The rear balancer needs to be aligned using a bolt in the maintenance hole.
Old Nov 15, 2008 | 07:38 PM
jay24k's Avatar
Thanks for the very quick replies. I'm going to use my torque gun to try to tighten the bolt. Is there anyway to do it by hand if you don't have a way to stop the pulley from moving?
Old Nov 15, 2008 | 08:02 PM
vinuneuro's Avatar
Default Re: (jay24k)
Put the car in gear, apply the foot and hand brakes.
Old Nov 15, 2008 | 08:31 PM
Acidcrakker's Avatar
Default Re: (vinuneuro)
and then what? Fly to the moon
Old Nov 16, 2008 | 08:12 PM
jay24k's Avatar
Impacted the bolt and joker went on tight. Honda is going to double check it so I feel safe.
Thanks guys.
neoc03
Jul 8, 2008 09:47 AM
bigizsosexy
May 21, 2008 03:13 PM
omgwtfbbqcrx
Feb 16, 2006 09:38 PM
hon
Sep 21, 2004 03:54 AM
fullracegsr
Apr 27, 2003 05:00 PM
