throttle body problems
you cant spell. are you throwing a check engine light? try unplugging your ecu and plugging it back in, did you recalibrate your tps? did you get the tps and map sensor messed up? go to a mechanic....
Originally Posted by Hanmin
you cant spell.
OP.. it could be your idle air control valve..(check the little screw on the throttle body and everything..)
no there is no check engine light and i already unplgged the ecu many times..! still cant figure it out..!
AD_NAPCO
Honda CR-V & Element
Nov 8, 2015 08:17 PM
performs
Mar 25, 2011 10:32 AM
LSVTEC 91 Civic
15
Oct 28, 2005 06:16 PM
