axle problem!
I helped a friend change his clutch and we have everything put back in except for the passenger side drive axle wount go back into the trany! What could be the problem? I checke the teeth to make sure they werent bent or worn and they arnt! Am I doing something wrong?
I guess in theory you don't need it, but I have always used it.
I put a piece of wood 2X4 on the hub end of the axle and hit it with sledge hammer, while trying to make sure the axle and hub are level.
ive noticed it helps ALOT to grease the axles really well!
grease the axles oil seal and the whole shaft.. grease also helps hold that snap ring centered.
once i greased mine up they slide right in place!
Yeah! Lube it up!!!
First make sure the end of the axle is square with the trans, then try and twist the axle a bit while lightly pushing in in to the tranny until you can feel the splines lining up, then "just tap it in."
t3601
Transmission & Drivetrain
Dec 3, 2009 01:53 PM
