radiator hose problem
I am getting ready to put everything back into my car from my motor swap. Well I have ran across alittle problem.
I dont know where these go to? I have looked and looked. Searched...read my haynes manual, and still nothing. Help me HT!
yea cause i'm pretty sure those are transmission cooler lines. i'm assuming you swapped in a manual trans and those lines now have nowhere to go. which if thats the case, just leave em alone they won't hurt anything being disconnected.
Originally Posted by EFstyle
is your car automatic?
is that other hose going to the bottom of the radiator a little bit off the picture to the left? if so then yeah they are just ATF cooler lines...
Well thanks for the help, I kinda figured they were but I thought there was only supposed to be 1. Guess I will find out when I hook everythign back up.
Do you think I need to plug these or will they not leak?
yeah there should be 2... a feed and a return line. and there is no need to plug em up... whithout an A/T there is nothing in there to leak out
93(Civic)EG6
Nov 1, 2006 07:45 PM
mz3bo
Jul 9, 2003 06:44 AM
