Alternator from EG - Will it fit? (D-Series)
I'm finding conflicting information.. mostly because there is a lot of b-series tech info on my searches.
Will an alternator from an EG fit an EF? Yes/No.
Originally Posted by jlicrx
the EF alternator uses a 3 rib belt and the EG uses a 4 rib belt - it will physically fit though
Originally Posted by SIred91
If your crank pulley corresponds.
EG Civic D alternator as stated above 4 rib and EF 3 rib. EF uses roung plug, EG uses square I believe. I believe the tensioning being lil different as well far as spacing, because I know our alternator kit only works for the EF D alt.
Originally Posted by 2point2
so you need a 92-95 crank pulley to use a 92-95 alternator?
98gsr-808-91dx
Jun 2, 2010 04:45 PM
AllMotaEF9
Oct 12, 2006 06:06 PM
Jet Black
Aug 21, 2005 05:55 PM
