Weird Suspension Noise..... Help!!
I've got an 03 RSX-S w/ k24 bottom end. I'm hearing a loud ping/jolt normally when i turn right @ lower speeds. Like turning right at a stop sign. It really sounds like the spring. I really don't know for sure what it could be though.
I don't think it's my CV axles, because it's not a constant clicking. Just one jolt.
Any ideas/thoughts are much appreciated...
I know that kind of noise comes out of the front suspension bushings on the si's, maybe yours is similar. do you know if it's side specific?
Yea, i think it is. I couldn't tell you for sure, but the sound is so consistant it's hard to believe it could be making that exact noise on both sides
You tell us that you have a K24 bottom end (which helps us none), but you don't include anything about your suspension setup.
No way to answer your question with such poor detail.
I mentioned k24 bottom end because it is somewhat taller than the k20. I wouldn't know if axle position would cause it. Just puttin out there.
And it's stock shock absorbers, skunk2 springs, 18" wheels (i know, i know....)
My guess is that whoever put the springs/struts back on on didn't do so correctly. That or it's the beauty of Skunk2 engineering...
I'd buy some new springs/shocks and do it correctly. Until then, you're going to have a suspension that's inferior to a OEM stock setup.
Originally Posted by Todd00
Skunk2 you say? lol. Do a search in this forum for Skunk2 suspension components.
I guess your idea is viable..... but you really mentioned nothing specific. What about the springs are inferior? And how would that produce the symptoms i mentioned.
GagnarTheUnruly
Jul 26, 2011 02:51 PM
J.nguyen
Oct 1, 2006 03:17 AM
MulletManRockStar
Mar 6, 2005 10:26 AM
LegendLS95
Aug 12, 2001 06:16 PM
