modded 91 crx si $1750 - maine
Old Nov 15, 2008 | 05:33 AM
solfly's Avatar
Default modded 91 crx si $1750 - maine
1991 CRX Si
car is set up for autocross and has won me 2 class championships in the past three years with a second place by a point in between
is not a show car and would need minor bodywork for a sticker
car will come with steel wheels and generic tires
alignment is very agressive and would reccomend putting it back to stock before street use
Engine
Custom Rear Exhaust Section
DNX Header
DNX Mid Pipe
Modded Air Box
Transmission
B+M Short Shifter
Energy Suspension Shift Stabilizer Bushing Set
Suspension
Custom Extended Top Hats
EBAY Front Upper Tie Bar
Energy Suspension Poly Ball Joint Boots
Energy Suspension Poly Front Lower Control Arm Bushings
Energy Suspension Poly Front Sway Bar Links and Poly Bushings
Energy Suspension Poly Front Sway bar Mounting Bushings
Energy Suspension Poly Front Upper Control Arm Bushings
Energy Suspension Poly Radius Arm Bushings
Energy Suspension Poly Rear Lower Control Arm Bushings
Energy Suspension Poly Rear Sway Bar Mounting Bushings
Energy Suspension Poly Steering Rack Bushings
Energy Suspension Poly Strut Mounting Bushings
Energy Suspension Poly Tie Rod Boots
Ingalls Front Camber Kits
Ingalls Rear Camber Kits (Smart Arms)
KYB AGX Struts
KYB Struts Modded for Height and Travel
Megan Racing Coilovers
QA1 400lb springs
Race Alignment
Removed Front Sway Bar
ST Rear Sway Bar
Welded Rear Sway Bar Link Mounts
Brakes
EBC Yellow Stuf Rear pads
Napa AE Front Pads
Russell Stainless Hoses
Interior
New Hatch Lift Struts
Rebuilt Drivers Seat Using Spare Pass Seat
Old Nov 15, 2008 | 06:36 AM
user 98292739's Avatar
free bump
question why did you remove the front sway?
Old Nov 15, 2008 | 08:18 AM
JDM_rolex's Avatar
Default Re: modded 91 crx si $1750 - maine (solfly)
bump!
pmd
Old Nov 15, 2008 | 02:35 PM
IT GUY's Avatar
Default Re: modded 91 crx si $1750 - maine (JDM_rolex)
pm'd
Old Nov 15, 2008 | 05:20 PM
170whp-B16a's Avatar
Default Re: modded 91 crx si $1750 - maine (IT GUY)
pics of the minor bodywork?
Old Nov 15, 2008 | 08:28 PM
EFRue57's Avatar
Default Re: (The Lobster)
probably so the car wouldn't understeer in the auto-x events he competed in. bump for you. makes me miss my old rex.
Old Nov 16, 2008 | 04:34 AM
solfly's Avatar
Default Re: (EFRue57)
yes the front bar was removed because our autocross club runs 90% slower more technical courses the no front bar/22mm rear bar combo is perfect for this
for faster courses the hollow HF bar up front would be perfect
this setup makes the car very rear biased but also very compliant in tight manuvers
it certainly takes some getting used to and many people who drove it needed to be somewhat timid
i am going to run the same setup on my hatch next season
Originally Posted by solfly
these are the most recent pics
Old Nov 22, 2008 | 05:08 AM
solfly's Avatar
bump, if you pmd me pm me again cause the changeover messed them up
Old Dec 4, 2008 | 03:19 AM
solfly's Avatar
bump
Old Dec 13, 2008 | 06:31 AM
solfly's Avatar
rust pics, honestly not as bad as i though it was
Old Dec 27, 2008 | 05:28 AM
solfly's Avatar
back up top
Old Jan 4, 2009 | 11:00 AM
solfly's Avatar
back up top
bump
Old Jan 27, 2009 | 02:20 PM
solfly's Avatar
bump
$1500
sepheroth
May 19, 2015 10:09 PM
solfly
Jan 29, 2009 02:13 PM
solfly
Northeast (Sales)
13
Jan 27, 2009 02:25 PM
g2b2
May 2, 2007 10:37 AM
scratchline20
10
Apr 30, 2003 09:00 PM
