DIY: interchangeable door panels inserts for eg/ ej1/2
Old Nov 15, 2008 | 12:57 AM
CaptWalt's Avatar
Default DIY: interchangeable door panels inserts for eg/ ej1/2
so basically i get bored with my door panel inserts.. ive already done them in crossword puzzle pattern and then moved onto the "happy monster" pattern... and since it was such a pain in the *** i figured it'd be cool to be able to have many inserts and change them as i please but as we all know honda made this impossible due to their melted plastic rivets that we have to drill out... so i dont know if anybody has already had this idea (probably) or if anybody else made a thread about this (probably) so i just decided to make one...
SUPPLIES I USED:
all-thread cut into short pieces
washeres
nuts
8115 bonding adhesive
and well, the door panel insert and the pattern
steps...
first drill out your instert
do whatever patter you please on your insert i did "happy monsters"
get your pieces of all-thread, nuts, and washers
use your bonding adhesive
and glue your all-thread to the back side of your door panel... (i used the spot where the plastic rivets are to reuse the holes on the inserts) and tape down the all-thread so they stay striaght and let it dry for 24 hours minimum
after that, place your insert through the all-thread and tighten them down with the nuts and washers...
and enjoy your interchangeable insterts...
ps... make sure the all-thread is short enough so that it fits inside the door when you stick it on... you may have to cut them more after they are already glued down although i would not recommend waiting that long as you might break the glue...
i hope this was helpful and not a repost...
Old Nov 15, 2008 | 01:26 AM
hookedonponics's Avatar
that's interesting to say the least
Old Nov 15, 2008 | 07:37 AM
darkblackH2B's Avatar
Default Re: (hookedonponics)
good idea. Is that how long you left the all thread on yours? and that didnt hit the inside of the door?
Old Nov 15, 2008 | 07:31 PM
CaptWalt's Avatar
Default Re: (darkblackH2B)
yeah... i had to cut them again... so like an inch would probably be a good length.. cus i cut mine down to 2 inches the first time...
Old Nov 15, 2008 | 07:46 PM
esoterEK..'s Avatar
Default Re: (CaptWalt)
niice!
i hate taking off my door panels though!
A for creativity
Wrona
Oct 12, 2011 04:35 PM
teamV eg
Feb 19, 2007 09:02 AM
JDMB18CEJ1
Jun 20, 2005 03:15 AM
B16EJ
Jan 24, 2004 08:05 AM
FD3S
Sep 6, 2002 04:16 PM
