ring hrned16y8 in 94 wiring help ahhhh
Im swapping a 97 d16y8 into my 94 hatch, the wiring harness is cut but I have the ecu. The stock d15 harness is also cut. My question is what will I need to wire this up? Could I get another harness for my car stock and swap the dizzy and whatever else? Or would I need the d16y8 harness and use that ecu?
Modified by keep_h8n at 1:16 AM 11/15/2008
you need to give us a better idea of what the problem is if you want some good answers.
Is the engine harness cut? or is the car harness cut? Either way, you probably need to get a new harness.
93civicjaydm
Nov 10, 2006 11:36 AM
Rusty Shackleferd
Jan 25, 2005 11:28 AM
