good or no good?
Old Nov 14, 2008 | 09:25 PM
INTEGRA LVR's Avatar
Default good or no good?
i have a b18a non v tec im just trying to build a decent head so far i have skunk 2 stage 2cam shafts, skunk 2 dual valve spring, retainers,aem tru time cam gears,and its ported and polished.
is this good so far?
thank
Old Nov 14, 2008 | 10:48 PM
majinsoftware's Avatar
yup thats good, get it tuned with a raised revlimit. 500-1000rpm above stock is the max I would recommend intill you started doing bottom end work aswell.
Balanced light weight crank.
light weight rods
light weight pistons
then you should be able to safely rev even more but by then youll need a hotter cam which will start to kill off low end power and idle.
Old Nov 14, 2008 | 11:08 PM
mnskateboarder's Avatar
sounds good but you should have used a vtec head
Old Nov 14, 2008 | 11:37 PM
bigkvn77's Avatar
Default Re: (mnskateboarder)
Your on the right track. Its pretty inexpensive to beef up the bottom end. You can get some oe pistons with a larger dome cc. pct's or p30's. Use the stock rods, and just get some arp rod bolts. Then get some management so you can get it all tuned and ready to roll. Its not always necessary to get vtec head. LS setups are perfect if your pockets are shallow.
it'll hold you over until you take a stab at boost.
Old Nov 15, 2008 | 08:37 PM
bump
Old Nov 16, 2008 | 05:58 PM
anyone else your opinion
79hatch
Sep 29, 2013 07:43 PM
michaelprice83
Oct 10, 2008 09:16 AM
cbabyby
Mar 21, 2007 01:49 PM
lakai_19
Jan 28, 2007 08:22 PM
incognitoracerr
Jul 3, 2003 09:00 AM
