B16 NOOB
Old Nov 14, 2008 | 08:07 PM
VADERS_EM2's Avatar
Default B16 NOOB
ok where do i start. i been working on my project for like 5 months now. i bought an EM1 shell. (previously stripped) anyways long story short, i put in a b16a2 engine in it. i have never done this. i did it all by myself just learning all alone lol. my problem started a couple weeks ago. i had to gut my cat out cause it was clogged. so now im running my engine with no 02 sensors (the 1 after the header and the cat one) they are fried. the cluster i had installed had the check engine light bulb taken out. i think im running rich. im getting like 24 mpg. the engine has around 100k. i know my way around an enigine but im not a pro. i really need some good advice and i know H-T has some good advice. THANKS IN ADVANCE.
am i causing harm to my engine ruuning with no 02 sensors?
what could have caused my cat to go bad?
Modified by VADERS_EM2 at 9:18 PM 11/14/2008
Old Nov 14, 2008 | 10:57 PM
slo_hatch's Avatar
Default Re: B16 NOOB (VADERS_EM2)
idk what is causing your car to run rich...but my d16z6 runs rich as **** too and i cant figure it out. and yes....you can from what i hear ruin rings by running rich. bump for this guy...i would like to know what is going on.
Old Nov 15, 2008 | 01:22 AM
sol2hatch's Avatar
O2 sensors.
get them.
Old Nov 15, 2008 | 05:55 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: B16 NOOB (sol2hatch)
Originally Posted by sol2hatch
O2 sensors.
get them.
Old Nov 15, 2008 | 06:34 AM
VADERS_EM2's Avatar
but if my cat is gutted. wont that just ruin the o2 sensors? which o2 sensors should i replace? is it a must to have a cat? im lost lol. H-T is my only hope.
Old Nov 15, 2008 | 06:57 AM
HitF8's Avatar
i don't have a cat on my car and i don't have any problems
Old Nov 15, 2008 | 05:32 PM
sol2hatch's Avatar
no, if your O2 sensor is out, it can ruin your cat cause it makes you run rich, but yours is ruined anyway, so it doesnt matter. You need to get your O2 sensors working if you want it to run right
Old Nov 15, 2008 | 06:07 PM
96-EJ6 B18C's Avatar
All you need is the primary (that's the one that goes before the cat) O2 sensor, this is the only one the computer uses for fuel trims. Then get a jumper harness and OBDI P30 ECU or an O2 simulator to take care of the secondary O2 (OBDI computer will not look for the Secondary O2).
Old Nov 15, 2008 | 06:59 PM
VADERS_EM2's Avatar
Default Re: B16 NOOB (96-EJ6 B18C)
BRO THANK YOU. you answered my question. thanks for all the other members and there info. is the jumper harness a bolt on deal?
Old Nov 15, 2008 | 07:58 PM
iamthefollower's Avatar
I think that the obd2 to obd1 harness is just plugging it in pretty much.. I know that the obd0 to obd1 has to be wired in and everything.
Old Nov 15, 2008 | 09:19 PM
VADERS_EM2's Avatar
Default Re: B16 NOOB (iamthefollower)
THANKS HOMIE. I GUESS I GOT A NEW WINTER PROJECT.
Old Nov 16, 2008 | 10:09 AM
Yup, just plug-n-play. Just give Rywire a call they will have what you need.
xci9v8icx
17
Jun 18, 2009 01:01 AM
dso
Jan 15, 2008 09:31 PM
donnie_437
Aug 22, 2007 11:08 AM
sirminder
Dec 29, 2005 01:04 PM
balut_penoy
Jul 28, 2005 01:16 PM
