55 Watt HID's?
Old Nov 14, 2008 | 06:26 PM
jcball3r's Avatar
Default 55 Watt HID's?
Does anyone know if 55 watt HID's are too much for the stock housing on a 5th gen prelude? I used 35 before, but wanted to know if 55 is too strong. Thanks
Old Nov 14, 2008 | 06:48 PM
dagle's Avatar
Default Re: 55 Watt HID's? (jcball3r)
do u have projectors? if not, then wtf.
Old Nov 15, 2008 | 06:59 PM
jcball3r's Avatar
Default Re: 55 Watt HID's? (dagle)
no, I meant stock housing, which means everything in a stock headlight. I don't plan on spending hundreds on dollars on projectors.
Old Nov 15, 2008 | 10:24 PM
Kronn 98SH's Avatar
stock bulbs are 55W, so yes, other 55W bulbs are fine.
Old Nov 16, 2008 | 02:13 AM
ethereal2pt2's Avatar
Default Re: 55 Watt HID's? (Kronn 98SH)
what do you mean? are you asking if theyre too hot or what?
Old Nov 16, 2008 | 04:04 AM
Dulluthkid_19's Avatar
Default Re: 55 Watt HID's? (ethereal2pt2)
They won't be too hot, they actually run cooler than halogen bulbs at the same wattage. BUT the problem is, those HID bulbs will scatter so much light because you don't have the proper housing for them, it will blind everyone on the road and you'll probly get tickets for it and they'll make you take them out. 55w is overkill, all you need is a 35w HID setup, and even that might blind people.
Old Nov 16, 2008 | 05:30 PM
jcball3r's Avatar
yes, I was wondering if they would be too hot. Thanks for the replies, I might as well stick with the 35watt since I know how they are. Thanks again
Old Nov 18, 2008 | 09:41 AM
ItsSlowYo's Avatar
Just aim them correctly and you will be ok. Though they will not pass inspections so make sure to keep your stock system as much intact as you can. You will have to swap in the stockies for inspection time.
Partizan
Lighting
Jan 4, 2011 10:00 AM
hondaluver12
Lighting
47
Mar 15, 2009 06:38 PM
IntegraJdmb18c1
Feb 21, 2006 09:20 PM
dc4drewH
Jul 12, 2004 09:38 PM
rluder21
Nov 19, 2002 06:38 PM
