omni map sensor on an 1991 ef stock intake manifold and throttle bodyfitment question
i current have the oem stock intake manifold and the stock throttle body. i need to get the omni map sensor to fit.
i was told that the stock ef d16a6 intake manifold and the throttle body wont work. i need to get an SI manifold and throttle body for the omni sensor to fit.
is this correct information?
if it is correct my next question is, i plan on getting the skunk2 intake manifold and skunk2 throttle body as well. will i have any other complications if i get this?
NO you dont have to cheange your intake manifold...........
you can still use your stock throttle body just put the vaccum like on it...
or get the obd1 up TB. and it will be a plug and play stock and cleaner look...
and with the skunk2 set up will work just fine, no mods or anything....
good luck.
good luck.
thanks bro.
just curious if you happen to have or know a link to a page with a picture where someone just hooked it up with the hose you mentioned? i wanted to see how not so clean it would look that way.
the d16a6 manny IS the Si manifold
is the SI manifold the same on a 92 and a 91?
93delslow315
Apr 6, 2010 05:55 AM
shahriar35
Jan 31, 2010 12:13 AM
SPD DMN
Apr 12, 2008 08:33 AM
