new motor in teg starts up and revs to oblivion w/o touching throttle
Old Nov 14, 2008 | 03:16 PM
surgd's Avatar
Default new motor in teg starts up and revs to oblivion w/o touching throttle
motor revs like the peddle is floored as soon as i start it up..........any suggestions pleez
Old Nov 14, 2008 | 03:33 PM
lmike6453's Avatar
Vacuum lines disconnected?
TPS and MAP sensors not accidentially switched?
Throttle body stuck wide open?
No CELs?
Old Nov 14, 2008 | 03:46 PM
LordAphotic's Avatar
like said above me... its gona be a vacuum issue...
your intake manifold and throttle body are the gateway for air to enter the engine... any holes or bad gaskets will cause the engine to rev up.. but if its reving up that badly then theres a lot of air getting into the engine
Old Nov 14, 2008 | 04:03 PM
wasabivtec's Avatar
Default Re: (LordAphotic)
I had a kid show up asking me the same question about a week ago. Turned out the kid he bought it from had taken the butterfly set screw out and put it back in from the top. Could be your issue, but more likely vacuum.
Old Nov 14, 2008 | 04:32 PM
Dartanian's Avatar
Default Re: new motor in teg starts up and revs to oblivion w/o touching throttle (surgd)
Yeah, you have a gnarly vacuum leak. Forget the IM gasket, perhaps?
Old Nov 14, 2008 | 10:22 PM
90Da9Ls's Avatar
i'd say vacuum leak my type r did the same thing when 1 of the holes on the intake manifold was plugged
thewrai6th
Sep 13, 2011 05:19 PM
AltimaXX
11
Oct 24, 2009 02:38 PM
Thatssojdm
Aug 8, 2008 08:42 PM
TylerB
18
Mar 24, 2006 08:58 AM
R6E6I6D
Apr 13, 2005 12:29 PM
