removing black paint from vc
Old Nov 14, 2008 | 01:49 PM
steveharrmr23's Avatar
Default removing black paint from vc
i would like to here how yall did it weather you used a special to or a cleaner
Old Nov 14, 2008 | 02:51 PM
egsleepercivic's Avatar
Default Re: removing black paint from vc (steveharrmr23)
aircraft stripper/remover , available at auto part stores, spray it on let it soak for what ever amount of time the can says, and the stuff will melt right off, rinse and repaet if needed, also get the stuff in the spray can it seems to stronger than the stuff that comes in non spray form
gl
Old Nov 14, 2008 | 03:53 PM
Benard's Avatar
yup aircraft remover is great stuff, be careful though, it will burn your hands
Old Nov 14, 2008 | 04:41 PM
bigkvn77's Avatar
Default Re: (Benard)
The aircraft stripper works wonders. You can save yourself 2 bucks if you purchase stripper from homedepot or lowes.
Old Nov 14, 2008 | 04:43 PM
1200 Hobos's Avatar
Default Re: (bigkvn77)
I heard not to use the spray kind but the kind you apply with a brush. The gooey stuff is better.
Old Nov 14, 2008 | 05:46 PM
90tegblueonblack's Avatar
Default Re: (1200 Hobos)
^^the gooey stuff is good, just spread it with a brush it will eat it all away, i used a wire brush to to get into the corners
just spray it very clean before applying your new paint
i didnt get it well enough the first time and it ended up looking real bad
Old Nov 14, 2008 | 06:55 PM
HondaLove517's Avatar
Default Re: (90tegblueonblack)
I remember this passed summer I was doing work on a car to remove paint and was using that stuff. It was hot and I was sweating so the little bit of wind was blowing the overspary right at me and I'll tell ya what, that sh*t burns, lol
Old Nov 14, 2008 | 07:24 PM
Default Re: (HondaLove517)
thx for the 411 all
Old Nov 14, 2008 | 07:31 PM
TegraD's Avatar
Default Re: (steveharrmr23)
ha, im poor so i used high grade sand paper i had lying aroung and some muscle... haha
Old Nov 14, 2008 | 07:48 PM
Default Re: (TegraD)
i have done that once already so i am going to drop some money
Old Nov 14, 2008 | 09:12 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
...paint remover is like $7. It works in about 20 mins. It also works a lot better than sand paper.
In 5 mins after application:
20 mins later (after soap and water and brake cleaner to remove the residue):
And then...
Old Nov 14, 2008 | 09:33 PM
INTEGRA LVR's Avatar
air craft cleaner works miracles but then again i just sand blasted mine!
Old Nov 15, 2008 | 11:53 AM
Default Re: (INTEGRA LVR)
Thx for the pics. how did you remove the cleaner?
i do not have access to a sand blaster.
Old Nov 15, 2008 | 01:52 PM
B serious's Avatar
You first scrape it off with a plaster spreader or something. Then you wash it off with a hose. Make sure you get all the stuff that went inside the VC. Get some brake cleaner and wash the VC inside and out with brake cleaner after you get it with a hose.
I wanted all the brake cleaner gone quickly from the inside of the VC, so I lit it with a propane torch...
Don't light your garage on fire like I almost did. Do it far away from stuff that can burn.
After that, let it dry out in the sun. If you're feeling like all the brake cleaner is gone, you can put the VC in the oven at around 150 degrees to dry. The paint will stick better when the VC is warmed to that temp also (if it's cooler outside).
Old Nov 15, 2008 | 03:11 PM
Default Re: (B serious)
thx
Old Nov 15, 2008 | 06:37 PM
Lucman's Avatar
Originally Posted by B serious
What kind of paint is that and where you got it from? because Im thinking of doing that but in a blue color
Old Nov 15, 2008 | 07:19 PM
Circusraven's Avatar
Default Re: (Lucman)
First you do this.
https://honda-tech.com/zero...ge=25
Then this.
https://honda-tech.com/zero...ge=26
Finish off with this.
https://honda-tech.com/zero...ge=27
Old Nov 15, 2008 | 09:24 PM
Default Re: (Circusraven)
i do not much care for the wrinkle looks
Serge L
Paint and Body
Apr 13, 2012 05:26 PM
aznboi_2
Paint and Body
Apr 17, 2009 06:08 PM
yuning83
Honda Civic (2006 - 2015)
Jun 25, 2007 04:05 PM
shanghaining
Apr 25, 2006 01:10 AM
islandgirl
Oct 26, 2002 05:22 PM
