Just wondering if a H22A4 head is compatible with an H22A block!
Old Nov 14, 2008 | 12:32 PM
JBirch_97Prelude's Avatar
Default Just wondering if a H22A4 head is compatible with an H22A block!
If someone can answer this asap, it would help me out a lot!
Old Nov 14, 2008 | 12:57 PM
98vtec's Avatar
moderator emeritus
Default Re: Just wondering if a H22A4 head is compatible with an H22A block! (JBirch_97Prelude)
yes. Use the A headgasket.
Old Nov 14, 2008 | 01:00 PM
Default Re: Just wondering if a H22A4 head is compatible with an H22A block! (98vtec)
Would having an A4 gasket effect compression?
Old Nov 14, 2008 | 01:01 PM
Would a H22A4 head gasket effect the compression?
Old Nov 14, 2008 | 01:06 PM
98vtec's Avatar
moderator emeritus
wont effect compression.
Always use the gasket for the block. The heads are the same (on the bottom)
Old Nov 14, 2008 | 01:09 PM
Okay, that one problem solved. the shop is telling me there is no spark and the compression 92/100/100/100 before doing a leak down test. I purchased a new Dizzy and coil but still no spark.
Old Nov 14, 2008 | 01:40 PM
gstrudler's Avatar
Yeah, that compression is extremely low. Which ecu are you using? Your original from the a4 or a JDM one? Any CEL?
Old Nov 14, 2008 | 02:35 PM
Default Re: Just wondering if a H22A4 head is compatible with an H22A block! (gstrudler)
The original! I keep hearing different stories from them so I don't know if they are the actual numbers. 1 week ago I was told that the head was good, and the only thing that was wrong with it was bent valves.
Old Nov 14, 2008 | 06:49 PM
gstrudler's Avatar
I would presume bent valves could produce numbers like, so that could be the only problem. However, you have to pull the head anyway to replace the valves and re-machine the head and valve seats, so you're going to replace the hg anyway, so that is kind of a mute point, but at least you know that you might have to replace a few valves too.
As far as no spark, have they tested the leads at the coil to make sure there is signal coming from the ECU? how about testing the coil wire to the dizzy (not while running!) and all four of the plug wires? was it a known good dizzy?
Old Nov 14, 2008 | 06:52 PM
jdmeg6118's Avatar
Old Nov 14, 2008 | 08:27 PM
This was the new head! I got cheated out of my money. Anyway I am going to buy another H22A$so my car will be legal!
CXtypeR
Dec 9, 2006 03:05 AM
SiMateoAko
Sep 1, 2005 09:06 AM
blackhatchb20
Dec 1, 2004 05:45 PM
t3hatch
Nov 8, 2004 09:49 AM
Jun 26, 2004 08:51 PM
