1998 honda accord v6 coupe tranny problems
Old Nov 14, 2008 | 09:21 AM
bdeschill's Avatar
Default 1998 honda accord v6 coupe tranny problems
today when i was leaving the bank i slammed on my breaks to avoid hitting a car the all or the sudden when i hit the gas my car bearly went anywere and the d4 on the dash was blinking green even if it wasnt in drive 4 and it wont shift out of 1st gear and wont go past 20 mph so i took it to the nearst shop. any adivce on what i should do like if i shoud convert it to manual or just by a new automatic tranny?
Old Nov 14, 2008 | 04:15 PM
hondadude's Avatar
Default Re: 1998 honda accord v6 coupe tranny problems (bdeschill)
I would first want to know what code came up for the Trans Control Unit.
Then there will be some FACTS to KNOW if the trans needs replaced.
So if you got a CEL from a spark plug misfire would you replace the engine?
Old Nov 15, 2008 | 07:02 PM
bdeschill's Avatar
Default Re: 1998 honda accord v6 coupe tranny problems (hondadude)
well they now said its not the tranny but its the electronic solenoid so any help there?
Old Nov 21, 2008 | 04:16 PM
makavelisolow's Avatar
could be the shifting solenoids
Old Nov 21, 2008 | 08:43 PM
P_Adams's Avatar
You have several:
As you can see there are several solenoid packs.
Check the filter screens under the shift solenoids (#9 in the illustration) and check continuity while you've got them out.
P
Old Jun 4, 2010 | 05:48 PM
changoleon1's Avatar
i have a 1998 honda accord and the check engine light came on so i took it to the mechanic and the code that they gave me was po740 or tcc and they said that i should rebuild the transmission so i want to know if there is an easier way to fix the transmission instead of rebuilding it.
loxienouis
Jan 6, 2011 01:09 PM
sub7viet
Jul 29, 2010 07:55 PM
shawn_g_18
Dec 18, 2008 02:14 PM
honda genome
Dec 9, 2006 12:22 PM
toyorotor
May 20, 2004 05:35 AM
