Drag III Install pics + Questions [BandWidth]
Old Jul 31, 2002 | 08:24 AM
sackdz's Avatar
Default Drag III Install pics + Questions [BandWidth]
This pass weekend myself and snake01 installed a drag kit on a buddies 99 Si. Just thought I'd share some pics
BEFORE:
A variety of "special" tools were used on the job. This included a BFH, some lotion, and of course, the SAWZALL
Turbo secks:
Giant screaching bug (Kayteedid sp?) that attacked us and I caught with a retractable claw:
Some random drunk dude who passed out nearby:
FINISHED!
Now you get to answer some questions.
1) How the hell is the air filter supposed to fit in here? As you can see the only way we could do it was to relocated the coolant res. We ended up putting it in the corner in the stock airbox hole.
Even still, the BOV rubs against the filter
2) Has anyone had to shorten some of the IC pipes to keep them from hanging too low?
3) The oil return bung on the pan is NOT welded above the normal oil level. It's near the top but still when removed a good quart and a half drained out. Is this going to cause problem?
Thanks
[Modified by sackdz, 12:29 PM 7/31/2002]
Old Jul 31, 2002 | 08:32 AM
speedymon's Avatar
Default Re: Drag III Install pics + Questions [BandWidth] (sackdz)
Wow must be nice to have a turbo. Oh well maybe i'll get the one i payed for from IP. Just maybe
Old Jul 31, 2002 | 08:37 AM
KC GSR's Avatar
I wish i could get turbo secks
Old Jul 31, 2002 | 08:49 AM
Trigun's Avatar
Default Re: Drag III Install pics + Questions [BandWidth] (KC GSR)
did you put the charge pipe on the wrong way? i thought the bov was supposed to sit higher and closer toward the intake manifold.
as for the air filter, you should be able to connect the pipes in a way where the filter goes over the radiator hose.
Old Jul 31, 2002 | 08:57 AM
sackdz's Avatar
Default Re: Drag III Install pics + Questions [BandWidth] (Trigun)
Well I'm told there are differences between the Integra and Civic drag kits. That was the only way the charge pipe would fit, and the airfilter as well
Old Jul 31, 2002 | 09:03 AM
Charles B.'s Avatar
is that an r2d2 bov ????
Old Jul 31, 2002 | 09:07 AM
Willard's Avatar
there is suppose to be another piece of pipe to push the filter over near the stock box location...
1.6L + boost =
Old Jul 31, 2002 | 09:29 AM
PrecisionH23a's Avatar
Was it the drunk guy who ziptied everything down in the engine compartment? Install looks good, try repositioning the filter so it doesnt hit the BOV, you can also loosen the clamp on the throttle body and try to move the piping so the filter doenst hit the BOV, its just a process of playing with it till it fits good... i can already hear the sexual jokes on that statement coming.
[Modified by GudeH23a, 1:35 PM 7/31/2002]
Old Jul 31, 2002 | 09:47 AM
brcivic411's Avatar
Default Re: Drag III Install pics + Questions [BandWidth] (GudeH23a)
dude, zipties oW3nZ yOo!
Old Jul 31, 2002 | 10:15 AM
Smashback's Avatar
Default Re: Drag III Install pics + Questions [BandWidth] (brcivic411)
He paid the extra money for the MSD 6A in the unpainted box that says SCI, he might as well buy some .05 cent sheet metal screws so it don't rattle around and crap out on him!!!
[Modified by mplex2000, 7:15 PM 7/31/2002]
Old Jul 31, 2002 | 10:43 AM
zcivic91's Avatar
Default Re: Drag III Install pics + Questions [BandWidth] (mplex2000)
by the looks of ur turbo setup and the other one..ur charge pipe looks like its in backwards...turn it around so the bov is closer to the tb..
Old Jul 31, 2002 | 10:48 AM
EFFECT's Avatar
Default Re: Drag III Install pics + Questions [BandWidth] (zcivic91)
Dont forget to put the clamp back on the coolant line
Did you have to shave the block at all to get it in? Ive installed a few rev hard kits on Si's and the fitment was CRAP, wondering how drags is.
Old Jul 31, 2002 | 11:34 AM
sackdz's Avatar
Default Re: Drag III Install pics + Questions [BandWidth] (EFFECT)
Haha actually yea we put that clamp back on but forgot the TB one on the intial test drive. Coolant leaking down all over the headgasket thought that it fried olo.
Fit shitty as well. I'm pretty sure the charge pipe fit in only that way but I'll screw around with it again. Either way, there doesn't appear to be a way to fit in the air filter without moving the coolant res with the pipes provided.
[Modified by sackdz, 3:35 PM 7/31/2002]
Old Jul 31, 2002 | 11:38 AM
b00stedsi's Avatar
we had to shave.
Old Jul 31, 2002 | 12:54 PM
sackdz's Avatar
Default Re: Drag III Install pics + Questions [BandWidth] (turkish)
woah. what part of the block are you shaving?
Old Jul 31, 2002 | 02:01 PM
turboex's Avatar
What BOV is that?
Old Jul 31, 2002 | 02:03 PM
Charles B.'s Avatar
Default Re: Drag III Install pics + Questions [BandWidth] (turboex)
What BOV is that?
i think its an r2d2. can someone verify?
Old Jul 31, 2002 | 03:19 PM
sackdz's Avatar
Default Re: Drag III Install pics + Questions [BandWidth] (SuperDuperEG)
What BOV is that?
Blitz super seq i think? Don't remember but it is a blitz
Old Jul 31, 2002 | 05:36 PM
Willard's Avatar
it is a blitz
you are what?
Old Jul 31, 2002 | 05:39 PM
sackdz's Avatar
Default Re: Drag III Install pics + Questions [BandWidth] (Willard)
you are what?
****** blitzed
[Modified by sackdz, 9:39 PM 7/31/2002]
Old Jul 31, 2002 | 07:26 PM
PROFILES2000's Avatar
when in doubt make your own
i took an old aem piping and hackt it up and well it works, by the way look like you guys had a kick *** time installing that turbo kit looks good
(by the way i am in no way affiletated with gotkick.com but he did take a few damn nice pix of my car thanks again)
[Modified by PROFILEGSR, 11:28 PM 7/31/2002]
Old Jul 31, 2002 | 07:46 PM
ZygSpeed's Avatar
Default Re: Drag III Install pics + Questions [BandWidth] (PROFILEGSR)
Boost OWNZ!
Can't wait to drive my own. Ed
Old Jul 31, 2002 | 08:17 PM
FredoSP's Avatar
Default Re: Drag III Install pics + Questions [BandWidth] (Zygspeed)
nice pics
bigTom
Aug 6, 2009 12:22 AM
Benny Z
May 21, 2004 06:10 AM
nsxmatt
Nov 23, 2003 08:41 PM
gitwidit
Sep 25, 2003 11:30 AM
SleeperCivicEX99
Jan 25, 2003 03:28 PM
