Clutch Slipping?? Comp Stage 4
Old Nov 13, 2008 | 05:14 PM
R81_DC2's Avatar
Default Clutch Slipping?? Comp Stage 4
Hey Ht, i have a Competition stage 4 in my 96 integra gsr about a year old.(i did proper breakin period 500miles) This is a bit difficult to explain but when the car is in neutral and then i put it into first and take offf the car feels fine, BUT say if i take off and then stop without letting off the clutch, when i try to take off again i feel like the clutch is slipping. IF i take it out of first and put it in neutral and do it again it feels normal..
anyone have any ideas?
Old Nov 13, 2008 | 06:47 PM
teg_duty_08's Avatar
Default Re: Clutch Slipping?? Comp Stage 4 (R81_DC2)
ummmm, why are you stopping without putting your clutch in?? or do you just pop it out of gear, im hoping thats what you mean. Sometimes 500 miles isnt enough to fully break in a clutch, sometimes you need 1000+ to properly break it in. Did you replace/resurface the flywheel when you did your clutch? Are there any other modifications to the car? just trying to get an idea.
Old Nov 13, 2008 | 06:54 PM
R81_DC2's Avatar
Default Re: Clutch Slipping?? Comp Stage 4 (teg_duty_08)
im not stopping without the clutch in , im saying when i stop,by pushing the clutch in, stopping then launching again,(say in trafffic when a car stops then goes) it feels like it slips. even so after 500 miles i did not beat on the clutch anyway, did not replace flywheel and i doubt it was refinished. the car is stock minus a 2.5 exhaust and aem intake.
basically if i take off from neutral to first, as if im at a dead stop and i put it in neutral the car launches fine, if i take off, then stop, not putting the car back in neutral just leaving my foot on the clutch and launching again it feels funny
Old Nov 13, 2008 | 07:01 PM
I geuss im a little confused, but not resurfacing a flywheel is BAD when replacing teh clutch. Hot spots are a killer to new clutches. not to mention a stage 4 is waaayyy overkill for your car, not to bash or anything. Im geussing that whoever did the clutch, screwed you by not resurfacing/replacing the flywheel. But im not 100% sure on why it works when you take it out of gear and then put it back in. some things just baffle me.
Old Nov 13, 2008 | 07:06 PM
R81_DC2's Avatar
well the reason i got a stage four is because im not planning on keeping it this way for long and it was cheaper then the stage 2. I have plan's for a boosted setup, i'm just annoyed at this feeling and at the time i needed the clutch and my differential changed fast because it is my daily driver. i mean it works either way , it just feels as if the clutch has a different grip point when i leave it pushed in as opposed to when i stop by putting it in neutral and then putting it back in first.
would getting a aftermarket flywheel fix this? or is it something else? im confused at the problem
Old Nov 14, 2008 | 07:59 PM
Now I think I understand whats up and what your doing. When you push the clutch in it is just rubbing against the flywheel/pressureplate rather than pressed up tight against both so it is heating/cooling differently. Both of these would cause your clutch to engage differently because of the expansion/contraction of the parts. Also, your flywheel being used may be causing this slightly, cant explain why though. If you are going to boost, then a new flywheel is a must, the stock on emay be a bit too heavy, but dont quote me because I am not boosted, nor am I a professional. I am just saying what makes sense to me.
99V-unit
Apr 22, 2008 05:13 PM
StolenTeg
Jan 30, 2006 08:52 AM
integra98
Aug 24, 2005 01:33 PM
shotty527
Nov 2, 2003 09:00 PM
vteg
Jul 30, 2002 11:09 PM
