widest rim that will fit
Old Nov 13, 2008 | 05:12 PM
rhdc2itr's Avatar
Default widest rim that will fit
what is the widest size wheels that will fit on our car with the stock fender? Anyone can help me out I'm trying to order my volks rims but I dont know what size I can push the limit.
Old Nov 13, 2008 | 05:25 PM
get RIGHT's Avatar
Default Re: widest rim that will fit (rhdc2itr)
8" is the biggest I have seen.
Old Nov 13, 2008 | 05:32 PM
CWITR's Avatar
How wide were you thinking about getting?
I have 16x8 +38 front and 16x7 +33 rear SE37Ks on my R. There is someone on H-T with 16x8 +38 TE37s all around on his red GSR. Exactly what will work with stock fenders is going to depend on the tire size, how low you are, how stiff your suspension is, and camber. You will not be able to go much higher than +38 offset with a 16x8 in the rear because of clearance issues for the inner lip.
Modified by CWITR at 6:40 PM 11/13/2008
Old Nov 13, 2008 | 05:35 PM
get RIGHT's Avatar
Default Re: widest rim that will fit (CWITR)
I use these same sizes on my AutoX setup.
Old Nov 13, 2008 | 06:36 PM
Status Sean's Avatar
Default Re: widest rim that will fit (get RIGHT)
depends on what you consider fit.
Old Nov 13, 2008 | 08:51 PM
Todd00's Avatar
I said I don't want a title!
What are you doing where you think you need the 'widest rim possible'?
8" wide will work, but I think a 7.5" is the sweet spot, with a 7" just behind that. If it's a daily get a 7" wide wheel. If you're looking to get every ounce of performance out of the car and don't mind a bit of rubbing or fender rolling, then get the 8" wheel.
But it also depends upon what tire you plan on running. It isn't as simple as buying the largest wheel you can fit.
Old Nov 13, 2008 | 09:38 PM
CWITR's Avatar
Default Re: widest rim that will fit (Todd00)
Originally Posted by Todd00
If it's a daily get a 7" wide wheel. It isn't as simple as buying the largest wheel you can fit.
Agreed. If I had a choice and was buying a new set of rims I would not get 16x8s. I only have this set up because I really wanted a set of 16" SE37Ks and these were the only ones I could find.
Old Nov 13, 2008 | 09:49 PM
EFsSuck's Avatar
Default Re: widest rim that will fit (Status Sean)
i remember seeing a 97R with some 16x8s, quick search:
2 16x8 35offset 5x114.3
2 16x7 35offset 5x114.3
tires are 205/40/16
Old Nov 14, 2008 | 06:01 PM
sti grip's Avatar
running 225 all around with some crzy jdm offset hahah just need some camber
Old Nov 15, 2008 | 03:26 PM
rhdc2itr's Avatar
Default Re: widest rim that will fit (sti grip)
I actually want the tires to sit flush with my fenders.
I haven't got my coil overs yet because I wanted to get my rims first then lower the car afterward so I know how much space I have. I figure that would be the best scenario since I dont want my fenders to rub.
Old Nov 15, 2008 | 03:36 PM
get RIGHT's Avatar
If that's the case then I suggest you get a 7" rim and the correct offset. It will save a lot of time and hassel, and it will increase your tire options as well.
Old Nov 15, 2008 | 05:15 PM
CWITR's Avatar
I actually want the tires to sit flush with my fenders. I dont want my fenders to rub.
It is going to depend on the tires you get. You could get 16x7 +33 rims, put 205/45 BF Goodrich G-force Sports on them, lower your car, and not worry about rubbing the majority of the time for street driving. On the other hand, if you put 215/45 Azenis on them, you are going to rub.
16x7 +32 with 205/45 G-Force Sports:
Old Nov 16, 2008 | 09:04 AM
DiRT!'s Avatar
16x9 +15
Old Nov 16, 2008 | 09:31 AM
crr's Avatar
crr
I have 15x8 +45 TE-37s with Hoosier 225/45/15 R6s on all corners.
Rear fenders are rolled (not flaired) and I'm using a 5mm spacer in the back (required to keep the tire from rubbing the trailing arm).
Old Nov 16, 2008 | 12:02 PM
93 Eg Couper's Avatar
Default Re: widest rim that will fit (DiRT!)
yo dirt...
i see you got 16 inchers
how many inches did you drop the car?
3 inches all around? maybe 3.5?
that looks dope bro
cant wait till next summer puttin black 16's on my eg and dropping it something like yours is
k sport coilovers baby
Old Nov 16, 2008 | 12:49 PM
Todd00's Avatar
Default Re: widest rim that will fit (93 Eg Couper)
Originally Posted by 93 Eg Couper
yo dirt...
that looks dope bro
You can't be serious.
There is a forum for showcars, and this isn't it.
Old Nov 16, 2008 | 01:14 PM
legomytego's Avatar
there is a yellow r with purple te37s on here somewhere i think his rims are 16x8
Old Nov 16, 2008 | 06:34 PM
sintype's Avatar
Originally Posted by DiRT!
that's crazy.
Old Nov 18, 2008 | 08:36 AM
PhatRoyale's Avatar
that's some crazy camber alright!
CWITR has got it down with just about the right setup IMO.
Old Nov 18, 2008 | 12:28 PM
nsxtasy's Avatar
H-T Order of Merit
FIRST decide on what make/model/size tire you plan on running. NEXT see what widths it's approved for. THEN shop for wheels in a width within the approved range. (You'll still need to deal with offset and possible rubbing.)
Here are the ranges of approved rim widths typically approved for tire sizes commonly used on the ITR:
195/55-15: 5.5-7.0
205/50-15: 5.5-7.5
225/45-15: 7.0-8.5
205/45-16: 6.5-7.5
215/45-16: 7.0-8.0
205/40-17: 7.0-8.0
Old Nov 19, 2008 | 06:06 AM
legomytego's Avatar
found it http://i237.photobucket.com/albums/f...5/sujakoby.jpg if this dosent work i dont no how to upload pics anymore
Old Nov 19, 2008 | 08:16 AM
DC206R's Avatar
does anybody know what kind of exhaust that red integra has?? i wnat something like that. sorrry not on topic.
Old Dec 13, 2008 | 11:53 AM
**** k sport
MadCivic1999R
Nov 11, 2011 05:18 PM
My_EFsedan
Sep 30, 2011 12:44 PM
silver05civicLXse
Sep 11, 2011 01:23 PM
Kentagious
Honda Civic (2006 - 2015)
May 5, 2009 07:39 PM
allmotor.joe
Honda Fit
Jul 4, 2008 04:11 PM
