adding ball bearings to non ball bearing turbo
Old Nov 13, 2008 | 04:54 PM
ashb82's Avatar
Default adding ball bearings to non ball bearing turbo
I have been thinking of getting one of those cheap turbos on ebay and adding ceramic ball bearings to it. i have a machine shop and felt as if could make a sleeve put the ball bearing in it. i talked to a bearing guy that i know, he said that he had some machine spindle bearings that would handle 150000 rpms. also will i have to get it rebalanced if i take it apart. i wander if these would work just want your thoughts.
Old Nov 13, 2008 | 05:13 PM
blinx9900's Avatar
Default Re: adding ball bearings to non ball bearing turbo (ashb82)
you can try it for ***** and giggles if you want to... as long as its not costly...
Old Nov 13, 2008 | 05:22 PM
ashb82's Avatar
Default Re: adding ball bearings to non ball bearing turbo (blinx9900)
yeah i have 2 turbonetics t3/t4 but dont want to mess them up. thats why i wanted to get cheap turbo off ebay.
Old Nov 13, 2008 | 05:59 PM
CRXdan's Avatar
let us know how it works out. you dont need to rebalance if you mark where the compressor wheel sat on the shaft.
Old Nov 13, 2008 | 06:43 PM
ashb82's Avatar
Default Re: adding ball bearings to non ball bearing turbo (CRXdan)
do you think i will have to get a water cooled turbo
Old Nov 13, 2008 | 07:49 PM
rota92
Guest
Posts: n/a
You won't get a water cooled, non BB turbo. There lies the even bigger problem lol
Old Nov 13, 2008 | 11:57 PM
CRXdan's Avatar
Default Re: adding ball bearings to non ball bearing turbo (rota92)
theres plenty of water cooled, non BB turbos
Old Nov 14, 2008 | 07:04 AM
Schister66's Avatar
Man U FTW
What are you trying to achieve? You're not going to pick up any spool time with the addition of a BB CHRA...that's just not how it works
Old Nov 14, 2008 | 07:10 AM
ashb82's Avatar
Default Re: (Schister66)
why would it not spool faster. would it let the shaft spin at a higher speed
Old Nov 14, 2008 | 08:06 AM
TheShodan's Avatar
Moderator
Default Re: (ashb82)
Because the wheel design is not matched with the STEEL ball-bearing system, so you don't really gain any efficiency. (this is why the T-seris Garrett line w/ ball-bearing cartridges didn't do so well for a bit.)
Ceramic bearings are not as sturdy as the steel-ball bearing system that garrett uses. I"ll put it like this. Ceramic ball-bearings were originally used in the 80's, until the bearings started disintegrating. Old technology, for little benefit.
Old Nov 14, 2008 | 08:14 AM
Schister66's Avatar
Man U FTW
To add to what TheShodan said, if you merely add a BB CHRA, you're not going to see an increase in efficiency; however, you may see an improvement in transient response (recovery after shifting). The BB CHRA's in the GT-R series are designed to work with the wheel design and together, the two components increase efficiency. Ball bearings alone dont offer much in the way of increased efficiency or spool.
This can be seen in the BW ETT series both S200 and S300. They're strictly journal bearing and spool just about as fast as the GT-R series. The main reason they dont spool as fast is due to the larger exhaust turbine; however, that does allow them to continue to make power into the higher pressure ratios...
All in all, this would be an expense for little to no gain. It's also an expensive fix if anything on the turbo has an issue...
Old Nov 14, 2008 | 08:51 AM
ashb82's Avatar
where is a good web site that discusses ar and trims so i can get a better understanding of what happens when i change Components of the turbo. i have always been interested in what makes a good turbo for your setup. the problem i always seem to find is that when you purchase a turbo the manufacture tells you that turbo x is good for 250 hp turbo y is good for 500 hp. but what determines this? there has to be something behind it . i would like to be able to put together a turbo and not just have someone tell me it is good for 400hp.
Old Nov 14, 2008 | 09:13 AM
Schister66's Avatar
Man U FTW
The first thing you could do is read about flow rates of various turbos and how that corresponds to power potential. The general rule is that for every 1lb/min flow, you get approx 10 bhp. That means that for a 57 trim that flows 51lb/min it can make 510 bhp. Notice that i said BHP (brake horsepower) and not WHP (wheel horsepower or actual power)
After reading up on that and how to calculate CFM and lb/min, you can read about compressor maps and get a general understanding...hell i dont even know much about how to read them, but i can get by . Then its just practice. Once you see Turbo X make a certain amount of power, you can generalise what it can do. Over time you'll start to put the pieces in place. If you have any questions, you can PM me or TheShodan
Old Nov 14, 2008 | 09:35 AM
TheShodan's Avatar
Moderator
Just to get you started.. a couple of pics. As Schister66 stated, compressor maps help, but that's 2 dimensional. You have to look at ALL angles of the turbo and use (turbine wheel, power need, Max rpm, displacement, VE, etc)
I post this too much, I really do....
Old Nov 14, 2008 | 09:44 AM
Schister66's Avatar
Man U FTW
Lol...you really do post that a lot, but its something that people should have a better grasp on. Another thing to look at and understand is AR...what it means and what it does. I'm speaking more of the turbine AR of course, but there is an aspect ratio on compressor housings; however, knowing the actual housing name (B, E, S, etc) is probably a bit more useful.
Old Nov 14, 2008 | 09:45 AM
HiProfile's Avatar
A few generalizations about turbos:
The Turbine (hot side) affects spool the most, as well as how much exhaust you'll end up flowing. IMO its really the most important factor. A compressor that can flow 200 lb/min (~2000hp) mated to a stage1 T3 turbine will NEVER make close to 2000hp, let alone 500.
The Compressor (cold side) dictates the pressure you'll be running at. A t04b wheel like a 60-1 can make 40psi, but it's efficiency drops way before that. When that happens, it 'blows hot air'. You use the comp map to find where your motor will be running, then you can calculate HP it could make (very rough value).
Turbos get rated based on a typical application. Setup details such as running a 1" exhaust vs a 5" exhaust will change actual output a LOT.
Back to the turbo you want to modify. One issue is that many ebay turbos aren't balance correctly, so the bearings will fail regardless of RPM capacity. THe other is covered above. Ball bearings aren't magical - they mearly reduce some friction, not improve the wheel designs. If there was enough friction to hurt spool by 500rpm, you'd be melting the shaft at idle.
Cliffs: turbos perform mostly based on the wheels & housings, not the CHRA bearings.
Old Nov 14, 2008 | 10:20 AM
ashb82's Avatar
Default Re: (HiProfile)
then what is all the hype about ball bearing turbos. could i get the same results with a journal style
Old Nov 14, 2008 | 10:41 AM
quicksilver1689's Avatar
i ♥ snails
well like stated before, ball bearing turbos have special wheel profiles that accompany the ball bearing design. They are opmtimzed or configured, they just didnt put a ball bearing package together and slap it on and say new turbo. There is alot of aspects when it comes to turbos.
Old Nov 14, 2008 | 10:44 AM
Schister66's Avatar
Man U FTW
Default Re: (quicksilver1689)
Exactly. They designed the GT-R series to compliment one another with both the wheel and CHRA design...
Old Nov 14, 2008 | 10:47 AM
ashb82's Avatar
can you buy these wheels or do the only sell them in bb turbo assemblies
Old Nov 14, 2008 | 10:52 AM
Schister66's Avatar
Man U FTW
You "can" buy them; however, the BB CHRA is a non-rebuildable center section. So basically if you have just the wheel, or mess up a wheel, the turbo is useless anyway...IDK how to explain it better than that. There may be people now who will touch those CHRA's, but to the best of my knowledge, having just the wheels would be totally useless
Old Nov 14, 2008 | 10:56 AM
ashb82's Avatar
where do you buy turbo parts at
Old Nov 14, 2008 | 11:08 AM
spoolin turbo s's Avatar
http://www.turbobygarrett.com would be good place to start looking
im sure theshodan could get about anything that exists that has to do with a turbo haha
Old Nov 14, 2008 | 11:09 AM
Schister66's Avatar
Man U FTW
To be honest, i haven't a clue. I just buy assembled turbos. If you want a custom turbo built properly to your exact needs, just PM TheShodan. He can get you something that will work with your setup and needs. I bought a turbo from him that isn't readily offered to the public and i loved it. Give it a shot...
Old Nov 14, 2008 | 11:29 AM
rota92
Guest
Posts: n/a
Holset makes these or something? I see you run that, that's why I ask.
