93 ej2 GSR redlines at 6500 RPM instead of 8200 RPM.
Old Nov 13, 2008 | 03:55 PM
jeffnerette's Avatar
Default 93 ej2 GSR redlines at 6500 RPM instead of 8200 RPM.
Alright i have a obd1 GSR w/ a skunk2 intake manifold and throttle body. it is not throwing any CEL's, VTEC engages properly and the car runs hard BUT it redlines at 6500 RPM instead of 8200 RPM. Please some help me . Thanks in advance
Modified by jeffnerette at 5:02 PM 11/13/2008
Old Nov 13, 2008 | 06:17 PM
come on, someone help me please.
Old Nov 13, 2008 | 06:18 PM
Sr420Det's Avatar
Default Re: 93 ej2 GSR redlines at 6500 RPM instead of 8200 RPM. (jeffnerette)
Did it just start doing it? or is this something you just put together
Old Nov 13, 2008 | 06:38 PM
Default Re: 93 ej2 GSR redlines at 6500 RPM instead of 8200 RPM. (Sr420Det)
its been doing since i did the swap about 6 months ago but i didnt think much of it because i was running a stock p28 automatic but i replace the ecu with a stock p72 and its still doing it.
Old Nov 13, 2008 | 06:42 PM
cashkeith's Avatar
what year 72 is it out of?
Old Nov 13, 2008 | 07:10 PM
no clue but i know it obd1. is there a way to find out on the ecu?
Old Nov 13, 2008 | 07:12 PM
cashkeith's Avatar
sometimes there is a year and i think auto has a lower rev
Old Nov 13, 2008 | 07:15 PM
how do you know if its automatic
Old Nov 13, 2008 | 08:34 PM
cashkeith's Avatar
Default Re: (jeffnerette)
what year is your motor the P72 is from 94-95 OBD-1 Integra GSR
Old Nov 13, 2008 | 09:46 PM
Default Re: (cashkeith)
motor is 94
Old Nov 14, 2008 | 04:21 AM
desperate bump for help
Old Nov 14, 2008 | 03:13 PM
Sr420Det's Avatar
I still would try another ecu, is your gsr a auto? Shouldnt it throw a code if its not a auto or theres a separate control module for the auto.
Old Nov 14, 2008 | 10:28 PM
Default Re: (Sr420Det)
I don't have another ecu to try. And my GSR is manual and the ecu I don't know. But it not throwing any CEL.
Old Nov 14, 2008 | 10:48 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Take it somewhere that has ECUs laying around so they can try a known good one into your car.
Why were you using a P28 automatic on the GSR swap?
Old Nov 15, 2008 | 01:43 AM
sol2hatch's Avatar
Default Re: (B serious)
its probably all he had. Try to get the correct ECU and try it. Make sure your check engine light is working too, i know it sounds stupid, but bulbs do burn out.
although, i dont think it would throw a code if its the wrong computer
Old Nov 15, 2008 | 08:32 AM
Default Re: (sol2hatch)
like sol2hatch said it the only ecu I had. And it was auto because I did the GSR swap/auto to manual conversion at the same time. My CEL works because it threw code 41 for o2 sensor and I changed it and in went out but still recline at 6500 RPM. I'm running out of ideas.
Old Nov 15, 2008 | 09:02 AM
gabydman2003's Avatar
check what ecu do you have, i know the older ones dont rev as high as the obd1
Old Nov 15, 2008 | 09:46 PM
Default Re: 93 ej2 GSR redlines at 6500 RPM instead of 8200 RPM. (gabydman2003)
obd1 p72
Old Nov 15, 2008 | 09:50 PM
slomofo's Avatar
GDD Member
Is the ECU JDM or USDM? Grab your stock ECU and compare it side to side, if it's JDM, the JDM ECU will be a little bit smaller than a USDM ECU. Auto GSRs were only available in the Honda Integra SiR-G, so if you've got a USDM ECU, then it can't possibly be automatic.
Also, I don't think the Auto ECU has a lower redline, I had an Auto LS/VTEC DB7 with JDM P30 AUTO ECU and it would usually shift around 7800rpm at WOT, but I never had the Auto P72, so I can't say for sure.
Usually a low redline is an indication of a timing belt one tooth off or a bad distributor.
Old Nov 15, 2008 | 10:09 PM
Default Re: (slomofo)
its the same size as the stock ecu thus making it usdm which means it manual. ok. now how would the distributor cause the low redline? i want to take care of things before i jump to the timing belt unless im 100% sure thats the problem.
Old Nov 15, 2008 | 10:33 PM
slomofo's Avatar
GDD Member
Check your timing belt first, it's easiest. Pop your valve cover off, turn the engine to TDC and look to see if the marks line up. Swap distributors with someone else to see if that's the problem.
Edit: On the distributor part, it's usually the coil that causes the problem. Your stock SOHC coil should be interchangeable if you don't have another distributor to swap over for a quick test.
RegCRVtec
Mar 1, 2009 11:58 AM
jeffnerette
16
Nov 24, 2008 02:27 PM
hndata9600
May 23, 2007 11:07 AM
moomakudafi
Jun 24, 2005 12:47 PM
pK1spooled
Nov 18, 2004 09:06 PM
