NEED HELP ASAP!!!!!!gsr
I have a B17 complete motor and i want to use B16 pistons to raise my compression and i just need to know what size rod bearings i need or if i can just get any b16 bearings and also if all this would even work and if it would put out a higher compression instead of the B17's???please HELP!!!!
http://www.zealautowerks.com/ ------------ compression calculator
Use the bearings for b17 because that would be the rods that you are using...
It will bump the compression as the pistons in a B16 have a slight dome, as opposed to the B17 piston. I think the b16 piston has a 6cc dome (the JDM b16 has a little more), while the B17 is a "flat top" design (0 cc dome). I would say you will be in the mid to high 10's for compression, as long as you haven't milled the head or decked the block. Good luck!
hOndafienD 04
Feb 10, 2005 04:00 AM
7rrivera7
Oct 20, 2003 04:55 PM
