Equalizer build
Old Nov 13, 2008 | 12:42 PM
mrdeadman's Avatar
They let me pick
Default Equalizer build
I am trying to build an equalizer for my circuits class. I just need some pointer in the right direction. Right now I think I am just using lpf, hpf and bpf with "*****" to adjust their cutoff frequencies. Then I will have "*****" to increase the gain on each of these? Does this sound right? If not please point me in the right direction. This is only a basic circuits class so I will be using caps, resistors and opamps to build first order filters, not second-order. Yes, these filters will "suck" compared to real ones but hey, it still gets the job done.
Old Nov 13, 2008 | 02:14 PM
nsxxtreme's Avatar
Default Re: Equalizer build (mrdeadman)
Well it's a little more complex then that. What you have described is an active filter that you can adjust the gain of the opamp based on a ****.
This should get you going on the right track
http://www.nuhertz.com/filter/
Their software does a good job at calculating gain and frequency. You can also spec the poles,zeroes and Q, and have it calculate what values to use to achieve that. It still requires you to know what your doing and set realistic expectations.
Modified by nsxxtreme at 3:20 PM 11/13/2008
Old Nov 14, 2008 | 09:09 AM
twentyhurtz's Avatar
Default Re: Equalizer build (nsxxtreme)
Yea thats a great link, also to note what he said, you can get a boost at certain freq levels, or you can set the boost at crossover points, but i would not do that, what kind of xover slops are you looking to go with? 12db ?
Old Nov 14, 2008 | 02:51 PM
mrdeadman's Avatar
They let me pick
Default Re: Equalizer build (twentyhurtz)
This is going to be comprised from single-order ciruits so I don't know if I can get 12 out of it.
Old Nov 14, 2008 | 06:05 PM
nsxxtreme's Avatar
Why are you restricting yourself to single order filters? With active filters its much easier to find realistic part values.
Old Nov 15, 2008 | 09:13 PM
mrdeadman's Avatar
They let me pick
I figured that would be easier. But if it isn't then I can do active filters. I just need to figure out the math as well.
Old Nov 18, 2008 | 08:01 AM
nsxxtreme's Avatar
Both are "easy" that software even solves the equation for you so you can check your math
*side note*
Honda-tech switched to Vbulletin now huh? Original owners must be gone.
steveteggy92
Mar 20, 2008 10:25 AM
cats_on_ice
Apr 22, 2006 06:45 AM
thesilverbullet
Honda Motorcycles
13
Sep 30, 2004 07:39 PM
Markus
Jun 4, 2003 12:36 PM
