has anyone tried venom im for the h22a?is it worth it.opinions pls
Old Nov 12, 2008 | 10:07 PM
hymertorres's Avatar
Default has anyone tried venom im for the h22a?is it worth it.opinions pls
in case im repeating a thread...i just wanted to know if anyone has gone with the venom intake manifold or the skunk2 on a jdm h22a and what to expect with either...only bolt ons on mine are catback apexi and aem intake ...nothing special but i was thinking of getting either manifold but wanted to see what other opinions are....i want to go NA but probably going to get boost sooner or later..cam shafts are going to be ordered sometime and i want my whole valve train to be skunk2..... i figured they would hold up to what ever i put to the test
Old Nov 12, 2008 | 10:22 PM
JTCdudeman's Avatar
Master H Technician
Default Re: has anyone tried venom im for the h22a?is it worth it.opinions pls (hymertorres)
I have the venom.. Its designed for FI. I would think twice about running it NA. It would be a huge power drop IM sure.
Old Nov 13, 2008 | 07:00 AM
NirVTEC's Avatar
Default Re: has anyone tried venom im for the h22a?is it worth it.opinions pls (JTCdudeman)
x2
The VENOM, STR, and Golden Eagle are meant for serious Forced Induction.....
Theres alot of other things to do before you should even consider a different IM.
Old Nov 13, 2008 | 09:58 AM
Default Re: has anyone tried venom im for the h22a?is it worth it.opinions pls (NirVTEC)
ok and is it worth it to get a 70mm throttle body on a skunk2 im ...and is it possible to bore the im to the 70mm because i think it comes 66 and what might be the side affects with doing the im that big? what will happen if the tb is 70 and im 66 will there be a problem with that?/?
Old Nov 13, 2008 | 12:23 PM
teefunk01's Avatar
I would consider what exactly you want to do to the car first NA or boost.....with either you should really tune the car with a new IM/TB combo
Old Nov 14, 2008 | 01:27 PM
ok so what should i do before the im+tb combo to the engine
Old Nov 14, 2008 | 07:39 PM
snobordboy's Avatar
Moderator
Hmm, about everything, it flows well enough stock for alot more than most people do. When you go higher compression and hot cams and such, then you may want to increase the im and tb flow rating. GregH, a member on here, is running 640 WHP with the Venom Im and a 65 MM Tb on his car, just for reference.
Old Nov 14, 2008 | 07:53 PM
NirVTEC's Avatar
Default Re: (snobordboi)
640whp through a 65mm TB?! Thats basically stock.......Weird.
Freshmodsegh22
Jul 3, 2015 09:03 PM
wegotmorrison
Aug 31, 2007 04:13 PM
sleepystyle
Aug 12, 2005 09:21 PM
B00ST2nR
Mar 23, 2002 11:40 PM
