93 honda civic b16 swap wont go past 3000 rpm hits a rev. limiter!
Old Nov 12, 2008 | 06:59 PM
mikester1222's Avatar
Default 93 honda civic b16 swap wont go past 3000 rpm hits a rev. limiter!
alright i have a 93 honda civic with a b16a swap and when i rev it up it wont go past 3000rpms in all the gears as well!! what could be the problems here? when i tried to get the check engine codes the check engine light just stays on and does not blink. need help what is causing this.
Old Nov 12, 2008 | 07:01 PM
SOHC_4dr's Avatar
i believe that the ecu is in limp home mode. you prolly have a bad sensor. pull the code and see what the issue is. oh and what ecu are you using?
Old Nov 12, 2008 | 07:48 PM
Default Re: (SOHC_4dr)
ok i found out that the fuel pump is pumping gas but never quits trying to prim and causeing the cel lights not to work! what could be causing the fuel not to be totaly primed?
Old Nov 12, 2008 | 07:54 PM
slo_hatch's Avatar
Default Re: 93 honda civic b16 swap wont go past 3000 rpm hits a rev. limiter! (mikester1222)
make sure your map snesor and tps sensor plugs are mixed up...try switching them.
Old Nov 12, 2008 | 08:17 PM
mikehawk's Avatar
Default Re: 93 honda civic b16 swap wont go past 3000 rpm hits a rev. limiter! (slo_hatch)
make sure you are using the correct ecu for that motor
Old Nov 12, 2008 | 09:46 PM
srbgti's Avatar
i agree its most likely ur ecu ( i think thats what was on my buddys car ill ask and get the info for you asap)
Old Nov 12, 2008 | 09:48 PM
96civic_hb's Avatar
Default Re: (srbgti)
Yes as stated before what ecu are you using?
Old Nov 13, 2008 | 04:51 AM
slob20ef's Avatar
Sounds to me like limp mode, did you try chipping your ecu yourself or mess with anything inside of it?
Old Nov 13, 2008 | 07:00 AM
lazii_boi08's Avatar
Default Re: 93 honda civic b16 swap wont go past 3000 rpm hits a rev. limiter! (slob20ef)
swap out the ecu
Old Nov 13, 2008 | 07:23 AM
team_exceed's Avatar
Default Re: 93 honda civic b16 swap wont go past 3000 rpm hits a rev. limiter! (lazii_boi08)
Originally Posted by lazii_boi08
swap out the ecu
i like how you just jumped into it and said four words that have no defining information to justify why you feel he should do that. You order him to do something worse than our local ASE certified's do! try explaining it a little better.
You should check your sensors as stated before. O2 sensor is bad in my buddies 01 civic, and it has entered the "limp mode" so he cannot rev past 3.5 either
Old Nov 13, 2008 | 07:50 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Default Re: 93 honda civic b16 swap wont go past 3000 rpm hits a rev. limiter! (team_exceed)
There is a check engine light on. So the ECU is trying to tell you that there's a sensor issue.
WTF are all these people talking about with "change out the ECU" and "It's the ECU" and "THE ECU IS A WITCH!!"
Also, Honda has a very liberal "limp mode" in older cars. It's hard to make it go into "limp mode". An O2 sensor will not send an OBD1 ECU or even a lot of Honda OBD2 ECUs into limp mode. There has to be some sort of REALLY serious sensor to do that. Usually, it goes into limp mode because it cannot run properly at all without the sensor. I highly doubt that an O2 sensor would send a 01 honda into limp mode. The O2 sensor is inactive under WOT, or even partial throttle angle...or in open loop. That's besides the point.
I'd say the most likely cause is that you got sensors mixed up. The TPS and MAP plugs are the same. You may have plugged those into each other. There are also a host of other plugs that are the same and are in a nearby location to each other.
VTEC and CTS are right by each other.
Knock and PS pressure and IAC are somewhat close to each other.
Make sure your IAT is plugged in correctly.
Check a wiring diagram. Make sure you have the right colors going to the right sensors.
You most likely have the MAP and TPS mixed up. That would be a very likely cause of your issue.
Check that. Get back to us if it fixed it.
Old Nov 15, 2008 | 07:12 AM
Default Re: 93 honda civic b16 swap wont go past 3000 rpm hits a rev. limiter! (B serious)
its a p28 and right now when i drive it im only getting like 15 mpg s is there like a fuel preassure sensor somewhere that would cause the fuel pump not to stop pumping?? what would cause this?
Old Nov 15, 2008 | 08:34 AM
B serious's Avatar
No. The fuel pump does not have an affect on fuel delivery. The FPR is contolled mechanically. This would not directly set a check engine light if the FPR was bad since the ECU does not monitor it.
One more time. Find out WHAT the check engine light is for. Check the how to flash a CEL thread sticky.
I'm pretty sure you have your MAP and TPS plugs switched up. Or your VTEC and CTS plugs switched up. Either would cause SHITTY gas mileage. But only the MAP/TPS plugs being switched up would cause the rev limiter.
Did you check those?
Old Nov 15, 2008 | 08:47 AM
EJ8_Enthusiast's Avatar
I love when people have these serious problems and neglect the most simple, effective ways to diagnose their problems:
get the damn code fool!
Old Nov 15, 2008 | 09:20 AM
slo_hatch's Avatar
Default Re: (EJ8_Enthusiast)
i agree completely with bserious. when i did my first swap i mixed the tps and map sensor plugs and it wouldnt rev past 3k. all you people are obsessed with limp mode...there is one guy (i dont think he posted on here) that says EVERYTHING electrical is in limp mode. its something simple im telling you...check your code.
Old Nov 15, 2008 | 12:24 PM
96civic_hb's Avatar
Default Re: (slo_hatch)
TPS-Red/Blk
MAP-Red/Grn
Old Nov 15, 2008 | 12:25 PM
alright for one i already tried to check teh cel flash problem is you cant check it till your fuel pump shuts off there for it wont flash!
~FOOL i guess i am ~
ok i switched the map and the tps but still doing the same thing! ANYONE HAVE A P28 COMPUTER FOR SALE I NEED ONE!!!
Old Nov 15, 2008 | 12:34 PM
96civic_hb's Avatar
Default Re: (mikester1222)
Not trying to make you look like or make you think I think you are an idiot but did you jump the pin with a paper clip to run the cel's?
Old Nov 15, 2008 | 12:59 PM
Default Re: (96civic_hb)
HAHA yes i have!!! im not that bad of an idiot!!!! right now im just in search of a p28 ecu!! and i believe that will fix my problem if that aint it then.... 93 civic with b16 for sale..........!!!
Old Nov 15, 2008 | 01:26 PM
96civic_hb's Avatar
LOL! How much? Will you drive it halfway?
Old Nov 16, 2008 | 03:49 PM
ha i will let you know when it comes time ha!!!
redtegsr
May 8, 2007 12:18 PM
OnePointFive
Feb 12, 2007 09:23 PM
goldhatchie89
Aug 28, 2006 12:30 AM
jel002
Jul 20, 2004 12:17 PM
