New Civic seats in an R?
Old Jul 31, 2002 | 05:34 AM
Rwecked's Avatar
Default New Civic seats in an R?
Just checked out the new Civic SiR (Canada) and the seats are made of the same material as the R but the shape is very nice and supportive. I figure this would make for a very stock-looking appearance while improving comfort and adding a bit of flair. Anyone know if these things will fit?
Old Jul 31, 2002 | 06:23 AM
GM2000ITR's Avatar
New User
Default Re: New Civic seats in an R? (PackinThird)
Two of the four bolts will line up. The easeiest way to make these fir is to use the front two stock holes (bolts are the same). For the rear holes. You will need to weld a small (.25" thick or so)plate to the underside of the raised floorpan rail structure(underside of the car is best). Place the seat in the car and bolt the fronts in and this will become more apparent. We just put RSX-S seats in a DC2 a few months ago (RSX seat frame=new Civic seat frame). Good luck! - Should look pretty sick, just don't forget to remove the red upper plastic "hole" trim and paint it black....it looks like a clown car w/ it in red IMO!
Old Jul 31, 2002 | 07:08 AM
PM-Performance's Avatar
Default Re: New Civic seats in an R? (GM2000ITR)
im gonna try it this weekend i told my girl im jacking the seats form the si to see how they fit in the R . . . . they look like they will be a bit off though, i just looked at the rails last night.
Old Jul 31, 2002 | 07:17 AM
TsunamiZC's Avatar
Default Re: New Civic seats in an R? (itr206)
si seats in the R.... more weight
Old Jul 31, 2002 | 07:45 AM
Default Re: New Civic seats in an R? (tsunami_zc)
im sure they are not too much heavier. . . im not keeping mine in , just wann see if they fit.
plus they are sooo omuch nicer.
Old Jul 31, 2002 | 08:24 AM
GM2000ITR's Avatar
New User
Just pull the side airbags out (can't use 'em anyways). They weigh about 5lbs. per side!
Old Jul 31, 2002 | 08:47 AM
ee-gsr's Avatar
GM2000ITR: do u have any pics of the extra piece that u had to weld on?
Old Jul 31, 2002 | 10:22 AM
GM2000ITR's Avatar
New User
Default Re: New Civic seats in an R? (ee-gsr)
I don't unfortunately. I may be able to take one in a few weeks when I go back to Miami.
jdmblu3s
Aug 16, 2007 10:20 AM
superemu
Jan 7, 2007 08:54 PM
PissedoffGS-R
Apr 26, 2004 12:41 PM
brcivic411
Feb 4, 2003 04:09 PM
