Daily Drivable Spring Rate // Koni/GC
I'm riding on koni yellows with Eibach Sportlines. Looking to do the entire koni/Gc Extended Top Hat. I do NOT track,drag, or race the vehicle. I do drive it 'hard' on the streets daily. I feel the sportlines a tad bit too soft in corners. I plan on doing some auto cross this up coming summer. What spring rates would be recommended? Or am i better of riding on the sportlines?
-00' civic coupe
-koni/Sportline Springs
-Daily Driven
-00' civic coupe
-Daily Driven
-00' civic coupe
-Daily Driven
-00' civic coupe
-Daily Driven
After you've gained some auto-x experience, know how the car behaves and what specific behavior you want to change, then consider moving to GC sleeves and custom rates. Once you get them, you'll want a nice rear swaybar anyway, so might as well start there and see if it is adequate for your needs currently.
I never thought of a swaybar. Will i gain a noticeable difference in cornering with-lets say- ASR brace and ITR sway?
It actually turned instead of trying to go straight and wide still.
Riding on Bilstein HD's and Sportlines as well.
I was considering switching to Koni Yellows and custom rate GC's, but opted to go the swaybar route instead figuring it would make the most difference. And I was right!
Another option i'd like to see is 10k/8k spring rate setup with the MFactory 19mm rear sway bar setup. I think this setup still is very tolerable on the streets and perfect for track use.
shpae
Dec 17, 2001 10:18 PM
