Doing Timing Belt, Where Does Maintenance Hole Lead?
Old Nov 12, 2008 | 05:23 PM
saikouEF8's Avatar
Default Doing Timing Belt, Where Does Maintenance Hole Lead?
im doing a timing belt, balancer belt and i had a drill bit in the maintenance hole on the back of theblock, i dont remeber pulling it out when i was done and ive turned the motor halfway away from TDC, but im afraid the drill bit may have broke, because i cant find it... wondering, if it fell down into the maintenance hole, where the hell could it have gone from there????
Old Nov 12, 2008 | 05:38 PM
saikouEF8's Avatar
Default Re: Doing Timing Belt, Where Does Maintenance Hole Lead? (saikouEF8)
bump
Old Nov 12, 2008 | 05:43 PM
c1v1c98's Avatar
It could be sitting in the oil pan or possibly somehwere in the crank hardware. Either way, a drill bit anywhere in your engine isn't good. You should have used something that wouldn't go all the way in. I use a screw driver.
Good luck.
Old Nov 12, 2008 | 05:46 PM
vinuneuro's Avatar
Default Re: Doing Timing Belt, Where Does Maintenance Hole Lead? (c1v1c98)
It's in the oil pan.
Old Nov 13, 2008 | 10:28 PM
Tarlacon's Avatar
I use the 100mm bolt like they suggest... just sayin'...
Modified by Tarlacon at 5:27 PM 11/14/2008
Johnathan Nuss
Jun 10, 2019 05:57 AM
mlab
May 18, 2014 01:38 PM
journeyquest
Sep 4, 2011 06:03 AM
VTgringo
Aug 11, 2004 03:47 PM
96LudeSiVTEC
Sep 25, 2002 08:29 PM
