Shifter Problems, when in gear -- still loose.
Old Nov 12, 2008 | 03:49 PM
EF9_TryMe's Avatar
Default Shifter Problems, when in gear -- still loose.
Okay, so everytime Im in gear like first all the way through fifth and even reverse the shifter is loose as hell, it goes from side to side ... sideways literarilly. Im thinking its the bushing that holds the shift linkage connected with 2 12mm long bolts to the chassis ?
Old Nov 12, 2008 | 04:00 PM
The_Honda_Guy's Avatar
From what you're describing it sounds like your transmission is ****.
Haha, just kidding. You're probably dead on about the bushing on the linkage being bad. Just jack the car up and crawl underneath he car straight down from where the shifter is inside the car. You'll see the two linkages running underneath the car to the transmission. Inspect the bushings for tears or deformation. I'm sure if the shifter is that lose you should be able to notice a problem pretty quickly.
Old Nov 12, 2008 | 05:56 PM
IhateworkingoncaRs's Avatar
I'm pretty sure it's the bushings by the end that connects to the tranny (the part thats held in by that dam roll pin LOL). I had the same probem.
Old Nov 12, 2008 | 06:44 PM
z6hatchboy's Avatar
Its more than likely shifter bushing right under the car, they're rubber and deteriorate over time
Old Nov 12, 2008 | 07:25 PM
jasony816's Avatar
Default Re: (z6hatchboy)
I think im having the same problems too. and I also think its the bushing/washer at the end of the shifter where it connects to the shift rod. I read somewhere that you should replace the rubber washers with new ones or with metal ones and i believe they are 3/8inch or 8mm.
Old Nov 12, 2008 | 07:55 PM
mikehawk's Avatar
Default Re: Shifter Problems, when in gear -- still loose. (EF9_TryMe)
you need a bitch pin and spring call honda its like $9
Old Nov 12, 2008 | 08:30 PM
ke98248's Avatar
Default Re: Shifter Problems, when in gear -- still loose. (mikehawk)
You can get an energy suspension bushings kito n ebay for cheap
Old Nov 12, 2008 | 08:54 PM
mattyv's Avatar
Default Re: Shifter Problems, when in gear -- still loose. (ke98248)
x2 they work great... which is why i have them o my car
Old Nov 12, 2008 | 08:56 PM
EG8AI's Avatar
Old Nov 12, 2008 | 09:05 PM
iamthefollower's Avatar
did it just start happening all of a sudden or what??? Anyways, like everyone else is saying, it sounds like your bushing..
Old Nov 13, 2008 | 10:57 AM
EF9_TryMe's Avatar
Alright, Thanks yall.
Old Nov 14, 2008 | 12:02 AM
8083tcman's Avatar
its the bushing under the shifer i had the same problem and then my shifer fell through the floor :{
DOUBLExDEUCEx22
Oct 25, 2008 09:44 AM
honda_coupe
May 26, 2007 02:08 PM
dohc_profile
19
Feb 15, 2007 07:43 PM
vinuneuro
Feb 9, 2007 03:36 PM
danteisme
Oct 6, 2005 02:57 AM
