STUMPED--crx no start issues
Here is my story. Last Wed i was driving home from school and decided to do a burn out at a stop sign. Well i did the burnout and got going like normal was shifting into 4th gear and my car bogged down and died. Oh and its the stock d15b2. I don't know if the burn out caused my problem or not.
Here is what i have checked: Fuel pump primes, Replaced main relay, replaced fuel filter, replace plugs and wires, 180 psi on all cylinders, gets great spark, turns over fine.
Check engine light is not on. No leaks of any kind, block is intact.
Please help me i don't like riding to school with my mom in her minivan.
that sucks, sorry to hear
well you have the 3 main things to get and keep the motor running.
spark - which you said is good
compression - you said 180 all around
and fuel - i would connect a fuel guage and see what your at.
or disconnect the banjo fitting and put it in a water bottle and turn key to "ON" position and see if your getting fuel or not.
spark/fuel/compression is your 3 main factor's
if all 3 is good, i would check into electrical then.
hope this helps.
let us know on your progress.
hope this helps.
hope this helps.
hope this helps.
Have you pulled your dist cap off and check the rotor? Make sure the screw didn't come out that thing.
Check your timing make sure the belt didn't skip a tooth.
Originally Posted by C_R_X_V_T_E_C
okay, you did a burn out from 1st through 4th gear....???
All joking aside, sounds like timing, belt or ignition
Kirk R
slavagc8
15
May 26, 2009 06:17 AM
civic89si666
Mar 20, 2006 04:54 PM
