VTEC problem?
so my vtec light (blue dashlight) is always on or atleast i think it is cause its always glowing blue. i jus bought a 96 civic and am not firmiliar with vtec, so im wondering if my valve is closing? or if its suposed to be like that?. cause i thought it shuld only come on when i hit vtec, which on my 96 civic si shuld be 4.8 rpm correct me if im wrong ?
seriously everytime someone refers to their vtec "kick" it makes me want to bludgeon an infant.
you do not have a light for vtec, sounds like your high beam light is on
and yes its true that you won't really feel vtec engage like you would on a b-series. on a d-series its a much smoother transition, not to mention i believe vtec on a sohc head only affects the intake cam, not the exhaust cam as well like on a b engine.
I don't know if you were referring to me. I never said it kicks in harder then a b series, I said it kicks in at 5200 rpms I have a boosted B series. So I know the difference between D and B. I'm not trying to be a dick I am just saying. Also it probably is his high beam light.
Modified by wrenchez81 at 4:17 AM 11/13/2008
Originally Posted by wrenchez81
dood ur an idiot!!! sohc has 1 camshaft so how could it only affect only the intake cam if both intake and exhaust are 1???
Modified by 94EG8 at 11:06 AM 11/13/2008
Originally Posted by 94EG8
I think you might want to take another look at how vtec works before you start telling people they're an idiot. SOHC Vtec does only fuction on the intake side. The cam has two sets of lobs on the intake side and and there are two sets of rocker arms on the intake side.
I think you might want to take another look at how vtec works before you start telling people they're an idiot. SOHC Vtec does only fuction on the intake side. The cam has two sets of lobes on the intake side and and there are two sets of rocker arms on the intake side.
wtf it isnt my highbeams ROFL. in the top left corner i have a picture even of my dash.
there is a blue light always on that clearly says VTEC.
it is always on, shuldnt it only flick on when vtec engages?
u guys really think i mretarded and th ink its my highbeams? rofl its liek a signal light i think id notice if it was a highbeam...
blue light in middle black letters. VTEC. is always on.. its clearly VTEC light ?'
and ita built into the cluster, like it is factory there.
I say
.Take a pic of your dash
i was just reading that ..... at right where the tach reads 5 grand theres an empty space that you could use...somethin about gluin it in like 3 different areas and ****... google instrument cluster with vtec light and youll see it there like i did... or if not play with different word combos.....
