Theromstat housing ground on engine harness
just liek it states above. i accidentaly cut my ground wire off my engine harness, im looking for a picture that shows where the wire is on the engine harness exactly
ground that connects to the thermostat housing is at upper right - there are 4 wires that connect to the ring connector
thanks alot man. one more question. on the starter there is another bolt where a wire should be mounted at (i think) http://importnut.net/forsale/dstarter-1.JPG to the right of the starter u can see the bolt.. is there supose to be just 1 wire going to the starter or 2?
2 wires to the starter - 1 from the engine harness (noted in the picture above) and the battery cable from the positive terminal of the battery - connects at solenoid
jdmdohcek98
Appearance Build Threads
Oct 24, 2009 03:52 PM
solsi2000
Apr 3, 2008 10:44 PM
