d16a6 with d16y7 good combination????
Old Nov 12, 2008 | 11:52 AM
QBANBOY407's Avatar
Default d16a6 with d16y7 good combination????
i have a d16a6 block and im about to buy a d16y7 head..
is it a good combination? i also have a d15b7 block!!!
all i need to instal the head is the timing belt right?
i have a complete d15b7 but the head is bad!!!
Old Nov 12, 2008 | 12:05 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: d16a6 with d16y7 good combination???? (QBANBOY407)
The Y7 head will raise CR a bit and has quench zones, but it was designed with fuel efficiency in mind rather than performance.
Are you planning any port work to this head?
If so try and find an A6 head or a D15B7 head as they have more room for really working the ports out. The world famous Bisi uses the A6 heads for his non-VTEC D builds, and since he ran 10's N/A with a carb'd 1.5L engine I'd say he knows what he's doing.
What kind of car is it going into?
Old Nov 12, 2008 | 12:07 PM
B18C5-EH2's Avatar
Former Moderator
Loved
BTW:
You'd also need a head gasket (order one for a 96-00 Civic EX as it's metal and cheap), intake gasket, exhaust gasket, valve cover gasket, and if you're doing a T-belt why not go ahead and do the water pump along with cam and crank seals?
Old Nov 12, 2008 | 02:28 PM
QBANBOY407's Avatar
Default Re: d16a6 with d16y7 good combination???? (B18C5-EH2)
im going to use the d15b7 intake manifold because thats the only 1 i have!!!
and thanks for telling me what to do!!!
can i use the spark wires from the d15b7 on the y7? and also the d15b7 distributor???
Old Nov 12, 2008 | 04:56 PM
QBANBOY407's Avatar
any one???
Old Nov 12, 2008 | 05:23 PM
94EG8's Avatar
Seagull Management
Wires no. D15B7 distributors are supposed to bolt to D16Y7 heads, but i've never tried it.
Old Nov 12, 2008 | 06:02 PM
QBANBOY407's Avatar
Default Re: d16a6 with d16y7 good combination???? (94EG8)
i thought i had to get me a obd2 distributor
Old Nov 12, 2008 | 06:09 PM
94EG8's Avatar
Seagull Management
You never stated what the engine was going in. If its going in a '92 - '95 get a D15B7 distributor, like I said they are supposed to bolt up to a D16Y7 head, but i've never personally tried it. If its going in a '96 - '00 get a D16Y7 distributor.
Old Nov 12, 2008 | 06:50 PM
QBANBOY407's Avatar
thats what i thought since the d16y7 is obd2
thanaks a lot man!!!!!!!!!!!!!!!!!!
Old Nov 13, 2008 | 08:24 AM
owneyboy's Avatar
the D16a6 and d15b7 is almost the same exact motor except its stroked up, has a more aggressive cam, and stronger internals.... if you have the a6 head use it for that block makes life a lot easier... if you use the Y7 you will have to use one if the Y7,Y8 head bolts and of course the dizzy and timing. the head gaskets are all the same except for metal ones and the grafite things. only difference. =] whats wrong with your b7 head?
Old Nov 13, 2008 | 08:27 AM
owneyboy's Avatar
use d16a6 if your gonna go boost or all motor... use d15b7 if you want to make it easier on yourselfr. deck height really doesnt matter those blocks are identical. but the d16a6 timing will be a really weird issue with the y7 head.
Old Nov 14, 2008 | 04:14 PM
QBANBOY407's Avatar
Default Re: d16a6 with d16y7 good combination???? (owneyboy)
damn man thanks a lot! the b7 head is all messed up and need new valves!
AND i guess ill have to get me a different head!!!!
MigsD16
Engine Machining & Assembly
Dec 17, 2016 05:17 PM
strike1545
May 24, 2010 10:42 AM
98exowner
10
Oct 12, 2008 10:03 PM
killer6993
Feb 18, 2005 12:11 PM
I8ayellowcrayon
18
Jan 29, 2004 11:42 AM
