Old tires new rims good question
driving a 94 eg I have a set of tires that are 205 45/16 well im looking for some rims to go with it i know i need a 16" rim but ..... Do i need to know anything else about the rim other then the height
Well, those tires are a bit too big for your car. If you already have them, you can try them to see if they rub. But once you wear them out and you have to buy new tires, the size you should be buying is 205/40-16.
When buying rims, you will need to get ones with the same bolt pattern as your car (4x100), the proper offset (I don't know what that is), the proper center bore (56 mm, I think) unless you get hubcentric rings, the best width for your tire size (16x7 should work best), etc. If you're buying new, the rim seller should know what fits your car. If you're buying used, find someone who is using them on an older Civic like yours.
Originally Posted by egjake
where do you thnk they are to big at
ahh ok thanks man uhh if i choose to get rims for them though ... what offset should i be looking at
Somewhere in the +20 to +45 range. The lower the offset, the more likely you'll need to add camber and/or roll/pull the fenders to avoid shredding the tires. +32 to +42 is the "very safe" range, in terms of not having to do other mods to fit the wheels.
