H22a4 to type s conversion, help. Pistons P5P JO
Old Nov 12, 2008 | 10:02 AM
Bangher4$'s Avatar
Default H22a4 to type s conversion, help. Pistons P5P JO
Hello, i have a 98 h22a4 in my civic all obd2. I bought some type S pistons and i keep hearing about different sizes. On the pistons they say P5P JO whats that mean?
What kind of rod bearing should i use? also what rings?
what precautions should i be aware of? Ive never done pistons before and this is block is funny with the FRM walls, wanna make sure i do it right.
so please any input would be great, thanks HT
Old Nov 12, 2008 | 01:08 PM
vinuneuro's Avatar
Default Re: H22a4 to type s conversion, help. Pistons P5P JO (Bangher4$)
http://www.spoonhonda.com . Read the piston selection section of the service manual.
Old Nov 13, 2008 | 09:39 AM
Bangher4$'s Avatar
Default Re: H22a4 to type s conversion, help. Pistons P5P JO (vinuneuro)
I dont see what your talking about.
TTT.
so far I need
Rod bearings (brand?)
Arp Head studs
Copper spray
Piston rings (OEM?)
that all?
Old Nov 13, 2008 | 01:11 PM
vinuneuro's Avatar
Dl the 5th gen service manual and go through that. It's got ALL the info you need.
Use OEM main and rod bearings. See service manual for choosing right color/size bearings.
Don't use head studs. You'll need to have the block's mains line honed if you want to use the.
Use OEM headgasket. Use the copper spray too if it makes you feel better.
Use only OEM rings. See section on how to choose correct size pistons and rings for your blocks.
Replace oil pump (comes with front main, and balancer seals).
Replace rear main seal.
Order parts through hondaautomotiveparts.com . They sell oem parts for 30% off retail.
Old Nov 13, 2008 | 06:03 PM
Bangher4$'s Avatar
ok, ill try that link again.
I will use all oem parts.
the copper spray was because im droping to a one layer. was goin gto seperate the oem gasket.
so i cant use ARP head studs?
thanks for info
Built4Battle
Feb 24, 2011 03:04 PM
SiTR
Aug 17, 2008 02:12 PM
bb4socal
Nov 14, 2006 09:07 PM
xDicktonesx
34
Oct 25, 2006 05:58 AM
CivicVX94
Sep 3, 2006 08:33 PM
