New Civic Si 4-door trans question
We are building a new Civic Si 4 door to run in Grand-Am Koni Challenge next season and are amassing spares.
My question is, does the RSX-S trans work in the new Civic?
I have access to RSX-S parts (trans), but just not sure if they are interchangeable.
TIA!
TIA!
Originally Posted by eficker
I have an opportunity to get a few inexpensively. Seems that the Civic ones are harder to find (for obvious reasons).
Did the RSX ever come with lsd?
Originally Posted by C27A4
i believe the DC5 ITR tranny came with LSD.
I'm sure this has been covered ad nauseum, but are all the gear ratios the same across all 6-speed k-series based transmissions?
1st: 3.27
2nd: 2.13
3rd: 1.52
4th: 1.15
5th: 0.92
6th: 0.74
Final: 4.77:1
06+ Civic Si
1st: 3.27
2nd: 2.13
3rd: 1.52
4th: 1.15
5th: 0.92
6th: 0.66
Final: 4.77:1
Only difference is in 6th gear, otherwise everything else is the same with respect to gearing between the two chassis.
Modified by K5^ at 5:29 PM 11/12/2008
Here's a very useful gear calculator from MFactory, might help you out.
http://www.teammfactory.com/ge...id=GT
Originally Posted by IT GUY
[img]https://i170.photobucket.com/albums/u266/duosonic66/K-seriesgearratios-2.jpg[img]
Originally Posted by FijiBlueFG2
Isn't it longer?
also playing with the mfactory calculator can help you understand what changes in gear ratio will do to things like maximum speed in a gear.
in addition to 6th being shorter, the final drive in the CTR's K20A (not the ITR K20A) would make it feel even shorter.
popescuracer
Jul 21, 2008 10:56 PM
