97 GSR into 94 LS swap question
Old Nov 12, 2008 | 05:59 AM
shadydb7's Avatar
Default 97 GSR into 94 LS swap question
I am swapping in a complete 97 GSR motor and tranny into my 94 LS..i am using the 97 harness to go with it but i noticed that on the passenger side shock tower the GSR harness has 4 connectors while the LS had only 3. the extra connector is a 3 wire connector. what is that extra connector for? also the previous owner of the GSR motor took out the stock dual runner manifold and swapped it for a AEBS instake manifold so now there are extra connectors that are not plugged. My question is how many extra connectors should there be?..Thanks in advance for any help and yes i already tried doing a search...
Old Nov 12, 2008 | 06:53 AM
sitinduk's Avatar
Default Re: 97 GSR into 94 LS swap question (shadydb7)
Not positive about obd ii 97 engine, but obd i gsr engine has vtec solenoid, vtec oil pressure, iab, and knock sensor. These wires and connectors will be missing from on an ls chassis. Rywire and Hasport both make sub harnesses for this swap.
If you do go with one of those, Hasport is more expensive, but the quality seems better. However, I've been using the Rywire sub harness w/o problems for over a year.
Also, are you using the obd ii ecu from the 97 gsr?
Old Nov 12, 2008 | 05:15 PM
shadydb7's Avatar
Default Re: 97 GSR into 94 LS swap question (sitinduk)
well those 4 wires i already have wired up..if you look at the passenger shock tower there is usually 3 plug connectors but on the GSR harness there is a 4th connector plug with 3 wires..im running a 95 gsr ecu (p72)
Old Nov 13, 2008 | 08:51 AM
sitinduk's Avatar
Sorry, don't know which one it is. Is it in this photo:
Or do you have any pics?
Old Nov 13, 2008 | 09:07 AM
shadydb7's Avatar
yes..it is the last plug all the way on the bottom..
Old Nov 13, 2008 | 11:25 AM
sitinduk's Avatar
Not sure what that goes to. What color are the wires in the gsr connector?
Old Nov 13, 2008 | 11:46 AM
weavertime1's Avatar
I am not a genious here, but I have done my fair share of swaps, and I honestly think it is for IABs, as it is not found on anything but gsr models in integras. The wire color appears to be the same, but as far as I remember '96 and up gsr have a three wire 4th plug, while '94 and '95 have a two wire fourth plug. That's the one issue I am having with saying it is for the IABs. I will see what I can find!
Old Nov 13, 2008 | 12:11 PM
shadydb7's Avatar
Thank you both for your inputs. Here is what i found on that 4th plug..The wire colors are as follows:
1)yellow/red
2)blue/red
3) white/red
if indeed these wires are for the IAB's then i will just forget about it since i am no longer running the stock manifold anyways
edit*
I actually did some wire researching and i think the blue/red is the CKF sensor wire and the white/red is the ckf sensor ground..if i'm right i dont need to worry about that since i'm running an obd1 p72...can someone confirm this info on the wiring?
Modified by shadydb7 at 4:19 PM 11/13/2008
Old Nov 13, 2008 | 12:51 PM
Could be, but I have that plug on my OBD1 GSR harness, and I don't believe OBD 1 systems have a CKF sensor...hmmmm?
Old Nov 13, 2008 | 01:33 PM
B18CUL8R's Avatar
Default Re: 97 GSR into 94 LS swap question (weavertime1)
automatic wire harnesses have 4 plugs
5 speed harnesses have 3
im not sure but im pretty sure.
could you possibly have an auto harness?
Old Nov 13, 2008 | 01:49 PM
Default Re: 97 GSR into 94 LS swap question (B18CUL8R)
GSR harnesses also have four plugs, and they never made an auto GSR in the U.S...I promise!
Old Jun 21, 2009 | 11:10 AM
TrboGzR's Avatar
so....nobody knows wat that 3wire plug is for?
DomesticIKiller
Oct 24, 2009 07:11 AM
LOVEthatDC2
Sep 29, 2009 11:33 PM
no2unenolife
Oct 6, 2006 12:29 PM
NCTUAN03
Mar 28, 2005 10:53 AM
integraautox
Jan 20, 2004 09:13 PM
