Couple questions about B18B1 in EG
Old Nov 11, 2008 | 07:54 PM
InTheLBC20's Avatar
Default Couple questions about B18B1 in EG
YESSSS, Im finally swapping in a b-series! My friend did the same swap in his hatch (i have a sedan btw), and he used his d-series shift linkage and he said it worked fine. Is he full of **** or will it really work? I have the linkage for the b anyways, but i just wanted to know. Also, as far as I know the stock mounts will work, only if you have the alluminum driverside mount that comes in EXs. Is this true also? I also have all the mounts from the b-series, but again im just curious. Hubs? I have DC integra hubs but i have heard stock civic ones will work fine. Again, just curious. If theres anything else i need to know, PLEASE LET ME KNOW. Im rippin my d out this weekend because im tired of my friends cars being faster than mine! Thanks!
Old Nov 11, 2008 | 07:59 PM
slo_hatch's Avatar
Default Re: Couple questions about B18B1 in EG (InTheLBC20)
if you have all the mounts and shift linkages...why not just use those?
Old Nov 11, 2008 | 08:49 PM
InTheLBC20's Avatar
Default Re: Couple questions about B18B1 in EG (slo_hatch)
True, but i just wanted a more experienced opinion on what works and what doesnt work
Old Nov 11, 2008 | 08:59 PM
slo_hatch's Avatar
well when i was gonna do my b series swap...they told me that i needed all the b series stuff...motor, tranny, mounts, shift linkage, ecu, and sometimes a wiring harness. so im not 100% sure...but im pretty sure the mounts will not work and the linkage do not either.
Old Nov 12, 2008 | 05:45 AM
94EG8's Avatar
Seagull Management
It doesn't, its too short and the way the stabilizer bar mounts to the transmission is different. The shifter itself can be reused however.
If you have the aluminum 3 post mount from an EX/Si or VX you can reuse that mount. Or you can use the civic style 2 post mount as long as you use both the bracket and the mount. The upper transmission mount can be reused in all cases provided that car was already a 5 speed. Everything else needs to come from a '94 - '01 integra or '94 - '97 Del Sol Vtec.
Civic hubs work just fine.
Old Nov 12, 2008 | 10:33 AM
InTheLBC20's Avatar
Default Re: Couple questions about B18B1 in EG (94EG8)
Awesome! thank you
Old Nov 12, 2008 | 10:56 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Small clarification:
The two front lower anti-roll mounts that bolt to the undersides of the frame rails needs to be 92-95 Civic as the Integra ones do not sit flush with the frame rails. These are the horseshoe shaped mounts.
Also are you trying to keep A/C? If you are that will dictate what a/c bracket is used. If you want a/c use either a 97 CR-V or 94-97 Del Sol VTEC a/c bracket. If not a/c then use the Integra bracket.
Old Nov 12, 2008 | 02:07 PM
InTheLBC20's Avatar
Default Re: Couple questions about B18B1 in EG (B18C5-EH2)
Those brackets let you use your stock a/c compressor, right?
Old Nov 12, 2008 | 04:41 PM
B18C5-EH2's Avatar
Former Moderator
Loved
Yes stock Civic compressor, lines, etc.
Old Nov 16, 2008 | 09:25 AM
InTheLBC20's Avatar
awesome, thank you
Old Nov 22, 2008 | 11:05 AM
InTheLBC20's Avatar
Default (cool new format BTW) Throttle cable?
What kind of throttle cable bracket do i need to use my stock throttle cable with a B18B1?
Old Nov 22, 2008 | 11:27 AM
Ya Digg's Avatar
You would be best off using the b18b1 throttle cable and bracket.
donvito#1
Apr 17, 2008 07:36 PM
PoWeRBaN_PaNdA
Mar 27, 2007 11:44 AM
PoWeRBaN_PaNdA
Feb 5, 2007 04:18 PM
wickedEFguy
Aug 21, 2002 02:59 PM
