civic hx o2 sensor problem
Old Nov 11, 2008 | 06:54 PM
slappy95633's Avatar
Default civic hx o2 sensor problem
ok so i have a 97 civic hx that i did a motor swap in to a d16y8 i am utilizing the hx harness. now i have read the post about doing this on a hx (https://honda-tech.com/zerothread?id=1302696) but the colors are different on my 4 wire plug i am trying to wire up. i need to know what the which black is what there is a black white and a black yellow i don't know which one is power and which is heater. i have the ground and signal down but don't know which is which on the blacks.
Old Nov 12, 2008 | 10:28 AM
Bangher4$'s Avatar
Default Re: civic hx o2 sensor problem (slappy95633)
Bump, someone's gotta know.
Ill research it later if nobody helps you.
Old Nov 12, 2008 | 10:32 AM
EJ8_Enthusiast's Avatar
not sure its what you are looking for but there are some wire color descrips -
https://honda-tech.com/zerothread?id=2280263
teal_dx
Oct 15, 2007 06:21 AM
nehring8
Feb 27, 2007 11:45 PM
redej878
Apr 20, 2006 08:27 AM
