Would you run this piston? dropped valve :(
R.I.P. Andy
I dropped a valve right when I was cranking the motor over to start it after driving it hard for 3 days. The car didn't even start, I heard the knocking around when turning it over and stopped immediately, I feel fortunate it didnt happen at 9k haha.
I don't need to hear flaming about me being dumb or ghetto, I AM dumb, ghetto, and cheap lol, no need to tell me about it. If you think it may work then I'll probably use it.
I don't want to take it out if I don't have to because the motor is new, the rings have seated, and I just put it in, I don't want to go through all that **** again.
Its a ls bottom end with b16 pistons, p72 head (rip), toda b's, supertech springs and retainers.
I somehow sucked a bolt into my cylinder, it wasnt as bad as yours, but I took it out anyways and took it to the machine shop....they hit it with some glass beads and you can hardly tell it was damaged
R.I.P. Andy
Originally Posted by siregcivic
how do you drop a valve, i really never understood it, i thought you could only do it from over revving?
(overrev cause bent valve and stress cracks, then it breaks off)
You "might" get away with that with a forged piston but the stock ones are cast.There is a good chance that it is cracked now (you might even see it from under the dome).When it fails it will break into a hundred pieces and ruin the block and head.
Andy, get a hold of me, I have the stock JDM bottom end off my swap, The pistons are good and I happen to want some GSR Pistons, maybe we can work something out, I also have a bunch of extra GSR valves. Hit me up if you're interested.
R.I.P. Andy
Originally Posted by sackdz
what does the head look like?
the head is not bad, it just needs 3 new guides and 1 new seat, theres just a few tiny knicks in the c chamber, none are even deep, its at the machine shop getting a valve job, new valves, a new seat and new guides.
Yeah, had the JDM B16 swap in my DA forever, I just swapped to a B18A bottom end Joe had, I need to re-ring it though, it uses a little oil. And hey, IM me about the vision seat, Alex wants to talk to you about the Homie Hookup pricing.
fitseries3
Nov 11, 2013 04:57 PM
