mpfi swap code 16
Old Nov 11, 2008 | 04:32 PM
1xfastxhatch's Avatar
Default mpfi swap code 16
i have a 90 hatch with the si mpfi swap. i had an injector go bad so i replaced them all now it will occasionally throw an injector code and start running like ****. i reset the ecu and it will run fine untill it decides to throw the code. help is greatly appreciated, i need to get home from school next weekend.
Old Nov 12, 2008 | 11:49 PM
Default Re: mpfi swap code 16 (1xfastxhatch)
bump this has me stumped
Old Nov 13, 2008 | 01:10 PM
Perfectionist's Avatar
The code 16 only indicates an interuption in the electrical path for the injectors, and they terminate at the ECU. If it's a 'hard' failure, I don't see how resetting the ECU would fix that, and an intermittient problem shouldn't cause a prolonged performance issue.
Old Nov 13, 2008 | 02:14 PM
Default Re: mpfi swap code 16 (Perfectionist)
so that means the problem is in the wiring correct ? the swap wasnt done by me and the bay looks like a rats nest
Old Nov 13, 2008 | 02:43 PM
intense4thgen's Avatar
start by cleaning the so called rats nest up then report back.
Old Dec 7, 2008 | 02:04 PM
finally went through the rats nest and soldered all the connections now it runs even worse
could the resistor box possably be going bad?
Old Dec 10, 2008 | 11:51 AM
for any body that was wonderin what was wrong it ended up being the main relay not any of the injectors or wiring
resoldered the main relay and she runs like a top
Old Dec 10, 2008 | 11:55 AM
Thanks for the update. And, as you discovered, the main relay is part of the electrical circuit path for the injectors.
ExtraBlackRex
Oct 28, 2010 05:18 PM
square_1
Apr 3, 2007 01:46 PM
typegsr
Apr 30, 2003 05:01 PM
ahc'monracing
Sep 22, 2002 01:11 PM
Aphrodavid
Feb 25, 2002 02:42 PM
