built B18C1 on 12lbs of boost, have a valvetrain noise
It was fine until the third time i sprayed it. it was a 30 dry shot to cool down the boost from the supercharger but now i go a ticking thats pretty loud ive adjusted the valves three times now and the noise is still there, its definitley top end, any input would be appreciated
Originally Posted by 97GSRcoupe
Theres no loss of power at all like a messed up valve
The spray tune up was a solid 12.3 to 12.5 on the wideband, i pulled 12 degrees of timing for 12 lbs of boost and the 30 shot, i figured that would be a safe
The plugs look fine. The heat line is rite in the bend on the plug. do you think im pulling to much timing? if so what should i go with.
1badteg
Oct 31, 2008 02:42 AM
TypeR1558
Sep 25, 2002 02:51 PM
