engine starts then dies immediatly
Old Nov 11, 2008 | 02:14 PM
goinghomesic's Avatar
New User
Default engine starts then dies immediatly
as the title says... iv visually checked literally everything n cant figre it out. distributor seems fine, theres gas, help
Old Nov 11, 2008 | 02:25 PM
stickyicky's Avatar
Did it just start happening?
Old Nov 11, 2008 | 03:12 PM
xsirenax's Avatar
we need more symptoms man.....like is it hard to start....does it happen all the time or only when cold?
does it stay on if you put gas?
details give us details
Old Nov 11, 2008 | 03:48 PM
jedb18's Avatar
Default Re: (xsirenax)
It's more than likely the electrical side of the ignition switch
Old Nov 11, 2008 | 04:00 PM
CRX Toad's Avatar
Default Re: (jedb18)
Ignition switch is bad in the steering column. It is a common problem.
If you hold the key in the start position is will run correct? As soon as you left it go back to the run position is shut off?
If so then the ignition switch is bad, call Honda get a buy a new one. Take the column apart, unplug the harness from the switch. Unscrew it and replace it. Not that difficult.
Old Nov 11, 2008 | 04:36 PM
fireant's Avatar
Default Re: (CRX Toad)
Also if you smell the stink fuel in the engine bay after it dies, worn out injector o-rings can cause this to happen.
Old Nov 13, 2008 | 01:05 AM
Chris EF9's Avatar
Happened in my EF9 recently. Stuffed ignition barrel contacts .
Old Nov 13, 2008 | 08:31 AM
bsixteener's Avatar
Default Re: (Chris EF9)
Had the same thing happen to me so I took apart the steering colum and removed the return spring then just installed a push button start directlly from the startor relay now it also is theft deterent because if you don't know where I put the button the car will not start.
ezcape
Jan 13, 2020 03:18 PM
fmirkled
Nov 28, 2009 02:52 PM
badfish2282
May 15, 2009 08:45 PM
infamouskillas
Feb 24, 2008 07:34 PM
crx_88_si
Jan 18, 2006 04:48 AM
